Fiesta-Si.com • View topic - No heat from heaters
It is currently Wed Mar 25, 2026 11:19 pm
 Post subject: No heat from heaters
PostPosted: Thu May 20, 2010 12:56 am
As in title, i havent spent too much time looking at it yet, blowers are fine, cars colling system is O.K no fuses are blown and the cable is moving the arm under the dash.....didint know if it was a common problem or if anyone else had experienced this?
Bill
 Post subject: Re: No heat from heaters
PostPosted: Thu May 20, 2010 1:10 am
maybe interior rad is blocked or if the pipes going to it are blocked iirc the interior rad can be blocked and not effect the main system as the water can bypass the interior rad.. not sure 100% sure tho.
or simple problems like is there any water in the system?
other than that it may just be a mechanical problem to do with the whole temperature slider assembly.
only time i had this problem is when my thermostat was blocked and even then it only went cold for about a min..
I WANTS BOOST!
PostPosted: Sat May 29, 2010 10:06 am
drain ur coolant system, remove the heater matrix, flush each pipe going to and from the matrix and reverse flush the matric itself or replace with a new 1, there only bout 40-50quid for a new one from a motor factors, and bleed the system until its red hot, shouldn't take more than 2 hours to do the whole job :)
PostPosted: Sat May 29, 2010 12:16 pm
ive had this and it took me ages.
firstly run the car to normal temp. check both the pipes going into the car they should be warm. if their cold remove the expansion tank cap just becareful that it dont boil over at ya and squeeze the pipes and see if they get warm it may take a bit of a while but ive just sorted mine out doing the same thing.
PostPosted: Sat May 29, 2010 12:54 pm
we get this on our vans at work, sometimes a kick sorts it out other than that we just replace
PostPosted: Sun May 30, 2010 8:38 am
lol a kick allway helps :D
PostPosted: Tue Jun 08, 2010 12:08 pm
Ok i feel really stupid.... I cant for the life of me find where the coolant pipes go into the bulkhead?! Can anyone give me a clue, many thanks, Bill
PostPosted: Tue Jun 08, 2010 12:17 pm
iirc they should go in under the inlet
PostPosted: Wed Jun 09, 2010 11:28 am
Ok the reason i couldnt find the two coolant pipes is because they arn't connected to the heater matrix anymore, looks like someone at some point has just joined them to each other.... :hmm:
I am assuming they did this because the matric leaked possibly?!
I attempted removing the matrix but i cant seem to drop it down not with that f**ing stupid metal bar that in the drivers footwell there!
Bill
PostPosted: Wed Jun 09, 2010 8:40 pm
It will drop down, its a bugger, but it does. When i did mine, i think i had to pull the back end down first, then it slides back a bit and falls on the floor :)
PostPosted: Wed Jun 09, 2010 9:25 pm
they are a pain in the arse to do but exactly what danny said they do come out. Tight fit though.
Users browsing this forum: Google [Bot] and 82 guests
