Fiesta-Si.com • View topic - clutch Question
It is currently Wed Mar 25, 2026 5:02 pm
 Post subject: clutch Question
PostPosted: Tue May 11, 2010 8:16 pm
Hi all,
Right then my clutch in my 1.3 is almost dead it bites hight :doh:
i have know that it needed doing when i got the car :doh:
so how hard is it to do one
or shall i not bother untill it starts slipping ?
thanks rob 8-)
 Post subject: Re: clutch Question
PostPosted: Wed May 12, 2010 2:01 am
the clutch isnt actually that hard a job, it just sounds daunting, cause it costs big bucks to get it done at a garage so people think its difficult,
but if you do it your self it can cost as little as £50 plus a few hours of time.
i done the clutch on my si on my own couple days before the last south meet, its pretty easy,
obviously you gotta take the gearbox off, easiest technique i've found so far is,
put car fairly high up on axle stands. take front wheels off,
get a ball joint splitter fork (halfords sell em for not to much)
a torx set on 3/8th or 1/2 drive, i think you need the T50 and a 17mm spanner\socket to loosen and remove the pinch bolts that hold the wishbone ball joins into the hub separate the wishbones from the hubs, (some Wd40 goes down a treat here, (mind the brake disks)
you can either pop the drive shafts out the box (oil goes everywhere) or pull the inner cv boots off and pull the cv's out of the cups,
you need an 18 or 19mm socket to remove the 4 bolts that hold the cross member on(if fitted)
13mm spanner/socket on drive to undo all the gearbox bolts including the ones that hold the starter motor on, gotta remove the speedo cable, (and speed sensor if fitted)
use a crow bar to seperate the box from the engine, finally use a jack tp support the gearbox cradle undo the 4 bolts that hold the cradle and box up and slowly lower the box down
this will reveal the clutch pressure plate, use a 10mm hex socket on the bolts that hold the pressure plate on, (dont use a mult point socket else you might round of the pressure plate bolts)
fitting the clutch is the reverse or removing it :D
make sure when you put the new clutch on that you light up the centre of the clutch to exacly the middle of the flywheel and pressure plate, else you'll have trouble getting the gearbox spline shaft in place.
simples
btw id probably wait until the clutch starts slipping before replacing it, my last clutch had a real high bite point, but when i took it off it had loads of meat left on it
(an extra body to help can make the job much easier especially lifting the box back onto the engine, its hard on your own trust me)
buttery biscuit boost
PostPosted: Wed May 12, 2010 3:02 am
not hard at all i done one on a fez at work (was 15 at the time) and it only took me 2 hours
PostPosted: Wed May 12, 2010 9:13 am
cheers
PostPosted: Fri Aug 13, 2010 8:53 pm
well i am back with a nother question will this fit as there is 2
http://www.eurocarparts.com/ecp/c/Ford_ ... df942&CLUK
PostPosted: Fri Aug 13, 2010 9:04 pm
Yeah why not
PostPosted: Fri Aug 13, 2010 9:23 pm
is that the one then lol
PostPosted: Fri Aug 13, 2010 9:45 pm
If thats the spec of your car then yeah, should be!
PostPosted: Fri Aug 13, 2010 9:51 pm
yhy it off the number plate
PostPosted: Sat Aug 14, 2010 9:15 pm
went and got one o day all the fun will start monday if weather is nice:)
PostPosted: Sun Aug 15, 2010 1:52 am
how far away do you live from mine dude?? I can always come over to lend a extra pair of hands mate!!
PostPosted: Sun Aug 15, 2010 9:57 am
ashmore park mate and cheers
PostPosted: Tue Aug 17, 2010 9:45 pm
fone but wont find out if ts ok time the weekend probsz as the brake lines are being changed :)
