Fiesta-Si.com • View topic - whats an EGR on a xr2i 16v
It is currently Wed Mar 25, 2026 10:02 pm
PostPosted: Thu May 06, 2010 10:39 pm
ive noticed on some MK3 fiesta threads people state "EGR removed" what is this egr thing ??
is this like a speed senser/ressistor in 1st,2nd gear ??
PostPosted: Thu May 06, 2010 11:00 pm
No, its a crappy system installed on cars to help with emissions etc and generally doesn't do well and gets in the way and is "another thing to go wrong" hence why people simply remove the box and pipes from the manifold and go to ford and buy 4 blanking plugs
You'll see it on a zetec manifold like injector shaped metal prongs that protrude from the manifold and run down to a box near the lower part of the engine
So to answer your question it doesn't do much, is built onto the exhaust manifold and is to do with controlling/improving emmisions etc
Its not important and wont effect the running of the car as long as it is all Completely removed
PostPosted: Thu May 06, 2010 11:23 pm
so will it make it faster !!! lol
also if i just buy a 4-2-1 fani_mold would that remove the egr thing ??
PostPosted: Thu May 06, 2010 11:44 pm
I took it off my old Si simply because it did nothing for the car and if it goes wrong then it can screw things up
The memory aint too good, a 4-2-1 would remove the need to plug a standard one i cant remember if the box part of the unit is attached to the engine and wired in if im honest you would have to look
you have to take the whole unit off, which if i remember is not a hard job :)
Dont think it 'helps' performance but its not much use and doesn't do much for looks so i'd rip it off
PostPosted: Fri May 07, 2010 9:50 am
So what does it look like sorry for sounding stupid ??
PostPosted: Sat May 08, 2010 9:32 am
take off the heatsheild on manifold and you will see 4 pipes, they go into a box, and then a rubber pipe comes out and goes into a valve
thats the egr system
PostPosted: Mon May 10, 2010 8:29 pm
So is It worth pulling it out ??
PostPosted: Sun May 16, 2010 8:43 pm
You wont really gain anything from removing it, probably doesn't work anyway, just the fact it makes your engine bay look alot neater.
PostPosted: Fri May 21, 2010 10:55 am
I'll leave it on my 2.0 engine then I want my new engine to look smart as gonna paint all the block up and make it look the nuts !!!
Users browsing this forum: No registered users and 137 guests
