Fiesta-Si.com • View topic - ARGH
 Post subject: ARGH
PostPosted: Sat Apr 17, 2010 1:18 pm
Im currently doing a 2 litre conversion on my 1.6Si. I have the engine in but when i turn the key I get ignition but no fuel pump prime, like when you hear it before you start the car. I have given it a direct feed of 12volts and it primes the lines and the car will start and run but not idle, it just cuts out straight away. Im wondering could it be anything to do with the pats system? any help is appreciated! thanks!
'Sideways Always'
 Post subject: Re: ARGH
PostPosted: Sat Apr 17, 2010 2:32 pm
have you used a pre pats 2.0 ecu?? codes for example desk, dale dewy?
PostPosted: Sat Apr 17, 2010 3:12 pm
Yeah ive got all the parts from the previous 2 litre conversion, its driving me nuts!!!!!!
'Sideways Always'
PostPosted: Sat Apr 17, 2010 4:24 pm
does anyone know if the inertia switch is linked to the airbag wiring in anyway as I have cut the airbag control wiring out?
'Sideways Always'
PostPosted: Sat Apr 17, 2010 5:21 pm
i think you should double check you're wiring on the ecu matey, maybe a couple of wires are misplaced!
PostPosted: Sat Apr 17, 2010 6:19 pm
didnt think its connected to the air bag, have you had the same set up ECU, keys ect running another 2litre? think the LED is ment to flash differently if PATS not signalling/accepting key ok, is the fuel pump relay working? i dont know if its a straight plug and play with a existing Si loom but seen mention of having to swap a couple of connections if using a cvh loom.
PostPosted: Sat Apr 17, 2010 6:23 pm
Everything seems to be in order to the my knowledge but maybe ive done something with the loom i wasnt suposed to as i did take it out over a year ago....
'Sideways Always'
PostPosted: Sun Apr 18, 2010 12:59 pm
Dont worry now people, eventually got it running and it then suffered oil starvation and died :cry: :cry: :cry: :cry:
'Sideways Always'
Users browsing this forum: Google [Bot] and 80 guests
