Fiesta-Si.com • View topic - Unlocking my car radio.
It is currently Thu Mar 12, 2026 7:00 am
 Post subject: Unlocking my car radio.
PostPosted: Sat Apr 10, 2010 4:10 pm
Ok, my radio is locked out. I bought the car like that.
The car is a 2001 Fiesta Freestyle.
I have removed the unit and there was a code written on top of the radio. I am presuming this is the correct code. Maybe it is not and that is where I am going wrong.
But, presuming it IS the right code, what i want to know is... what is the correct method for entering this code?
I can input the 4 digits, but what then? Do I have to press another particular button? Have tried any button but it locked out when i pressed the number 5 key and no other buttons seemed to do anything. Have to wait 30 mins between attempts :(
If all else fails I guess I will just go visit my local Ford garage, but I would rather get it sorted myself, with the help of you lot of course :thumbsup:
PostPosted: Sat Apr 10, 2010 4:48 pm
it could be the wrong code which is why its locking out as it sounds like your entering it correctly :? .
how many times have you attempted it mate?
a ford dealer will charge you aroung £25 to £30 just for the code :shock:
if you still need the code on monday give me a pm as ill be at work then and could give you the correct digits. :thumbsup:
PostPosted: Sat Apr 10, 2010 5:31 pm
I have attempted it 3 times I think. Now there is a '4' displayed. I think that is what the '4' means, 4th attempt that is.
If you could get me the code that would be sweeeeeeeet!
If I am still locked out by then I will PM you the serial number. I think thats what you need, yes?
Cool. Thanks
PostPosted: Sat Apr 10, 2010 5:35 pm
Yeah the 4 is the attempt number.
Just pm me the serial number. Think it's "m" then 6 digits?
PostPosted: Sat Apr 10, 2010 9:08 pm
PostPosted: Sat Apr 10, 2010 9:32 pm
Tourneo? Is that a ford :?
I can only get ford radio codes unfortunatly mate.
PostPosted: Sat Apr 10, 2010 9:46 pm
yeah, its the same as a transit but more cushy inside
PostPosted: Sat Apr 10, 2010 10:01 pm
My bad :red:
When you remove the radio is there a number starting with m followed by 6 digits? If not then I'll need the serial number aswell as the part number. If it's a transit I'm guessing it's the "m" number :thumbsup:
PostPosted: Sun Apr 11, 2010 11:22 am
i will check in a bit, is there any way of getting it out without the things you stick in it?
PostPosted: Sun Apr 11, 2010 11:25 am
You would need ford radio pins mate. Or sometimes people use the hook end of metal coat hangers but I've personally never tried that.
PostPosted: Sun Apr 11, 2010 2:12 pm
Loumiester, I managed to get my radio out with a set of DIY pins.
Basically they were U shaped metal rods, about 2 or 3mm in diameter. Someone at work gave them to me. Released the radio ok-ish. Bit of a struggle but she came out in the end. They did get stuck in the mechanism though :doh: and I had to use a screwdriver to release them.
Scamp, I am gonna PM you my radio serial number if thats OK. Tried the code again last night but to no avail.
Cheers
PostPosted: Mon Apr 12, 2010 7:49 pm
I now have tunes!
Many thanks to scamp :thumbsup: top fella. Thanks
PostPosted: Mon Apr 12, 2010 8:26 pm
I know on the old ford single din stereos, if it was a 4 digit code you used to press each number in accordance to the code and then press 6
For example: if the code is 2514
You will press on the radio- 11,22222,3,4444,6
Or 7578 - 1111111,22222,3333333,44444444,6
Etc.
I don't know if it is the same for the more modern ones.. Give it a go.
PostPosted: Tue Apr 13, 2010 4:33 pm
There used to be lots of code generator things around to get these, I have had to use them too many times after disconnecting batterys and then not being able to find the codes.
PostPosted: Sun May 09, 2010 7:45 pm
If u post up the seriel number, starts with an m and followed by 6 digits, i can get the code from work for free if u still need it
Users browsing this forum: No registered users and 100 guests
