Fiesta-Si.com • View topic - just want to double check this
PostPosted: Thu Apr 08, 2010 9:00 pm
bigger brakes.......
ive got mondeo calipers, pads and discs.
ive just read the guide, but i want to make this clear:
to fit the calipers: drill the holes to 12mm (got that bit :thumbsup: )
if i use mondeo discs: i need disc spacers and also grind the hub down???
if i use ST170 discs: they fit straight on???
also is the ST170 the focus? :doh:
need to know this asap as i wanna do this tomorrow :thumbsup:
cheers Rob
PostPosted: Thu Apr 08, 2010 9:37 pm
ST170 is indeed the focus :D
not done this conversion so dont know if they bolt on without needing to mod the hub :cry:
PostPosted: Thu Apr 08, 2010 9:42 pm
what mondeo calipers are you using ?
if they are from a mk2 v6 then you cant use the st170 disks as they are 300mm and the mondeo mk2's are 280mm
you shouldnt have to grind the hubs down just space the disk out 3mm iirc.
personally what i would do is sell the mondeo stup you have and buy one from a fiesta st.
its still 280mm and will bolt straight on without having to drill hubs and shiz
PostPosted: Thu Apr 08, 2010 9:50 pm
I think they are just off a standard mondeo. The discs that come with them are 260mm
I was hopeing to use these calipers as then I can go and buy some new discs tomorrow.
Do you know what discs will fit straight on with standard mondeo calipers?
Or if I get the fiesta si calipers and discs every thing is a straight forward swap? Just unbolt and bolt on?
Thanks rob
PostPosted: Thu Apr 08, 2010 9:57 pm
if your just going for 260mm upgrade then get a set off a post 2000 puma or mk5 fiesta zetec s as again no drilling or messing just bolt on
PostPosted: Thu Apr 08, 2010 10:46 pm
To be honest I never realised they were Only 260mm. The bigger the better really so I'd do 300mm if they fit under 15" wheels.
Can't I use bigger discs with the mondeo calipers I've got?
Or do I need bigger calipers?
If I stick with the calipers I got which discs shall I get? I want ones that don't need spacers.
I don't mind drilling out the holes but I don't wanna start grinding the hub and using spacers.
PostPosted: Thu Apr 08, 2010 10:51 pm
i had to space my wheel out 5/6mm when i had my cossie 4x4 set up put on :cry: , i didn't like it but it was fine for 2 odd years
got a cossie 4x4 set up in my shed :halo:
PostPosted: Thu Apr 08, 2010 10:55 pm
PostPosted: Thu Apr 08, 2010 10:58 pm
still have the spacers you'd need to get new discs and pads tho as mine were shot :cry:
PostPosted: Thu Apr 08, 2010 11:00 pm
what size discs will fit with them?
did you drill anything out or grind anything when you done them?
PostPosted: Thu Apr 08, 2010 11:03 pm
iirc they were 278mm disc's, will find the guide i used
no dilling neeed,iirc all you have to do is space the carrier out 5mm, i used 5 washers on each bolt to space them out
they were fine for the 2years i had them on the car :D
PostPosted: Thu Apr 08, 2010 11:05 pm
so all id need to do was space the caliper holder out with washers on the two bolts? and thats all?
sorry for all the questions lol :doh:
PostPosted: Thu Apr 08, 2010 11:06 pm
guide i used -
http://www.fiestaturbo.com/forums/exten ... s-vt29615/
info on the brakes
http://www.fiesta-si.com/modifications/brake-upgrades/
http://www.fiestaturbo.com/articles/brakes/
PostPosted: Thu Apr 08, 2010 11:07 pm
PostPosted: Thu Apr 08, 2010 11:09 pm
:D sounds much easier
do you want to sell your calipers and spacers? oh and the washers if you have them lol
PostPosted: Thu Apr 08, 2010 11:11 pm
i have no use for them :D
will pm you ;)
iirc i still have everything needed, except discs and pads :chill:
PostPosted: Thu Apr 08, 2010 11:17 pm
okay cheers mate
