Fiesta-Si.com • View topic - stiff gear change
It is currently Wed Mar 25, 2026 11:19 pm
 Post subject: stiff gear change
PostPosted: Tue Mar 30, 2010 5:32 pm
I have trouble getting in to gear and when running hot changing gear. Had the clutch looked at the garage and they say nothing
wrong with the clutch, changed the clutch cable, but still doing the same. Any thoughts???? dont think there is anything wrong
with box. the clutch pedal still at the same height as the brake pedal, but not much biting point on the clutch :banghead:
 Post subject: Re: stiff gear change
PostPosted: Tue Mar 30, 2010 6:25 pm
ding ding...round one of questions :lol:
when was the gearbox oil last changed?
is it a manual or auto pedal adjuster (white knob on the front of the pedal is the giveaway)
you say no real biting point..is it biting at the bottom or the top of the pedals travel.
is the linkage stiff..i.e push it into one position and it stays there?
Just trying to cover some of the bases from your description thats all :)
Jam.
PostPosted: Tue Mar 30, 2010 6:44 pm
is it stiff getting it in gear or does the gear linkage feel stiff at the gear leaver end could be ceased up linkage
PostPosted: Tue Mar 30, 2010 6:50 pm
[quote="Jam"]ding ding...round one of questions :lol:
Jam.[/quo
havent changed the gearbox oil since i had it (5years)lol, but got them to check it when i took it to the garage about the clutch change, they said it was fine. biting point is at the bottom of the pedal, i believe its auto pedal adjuster its a 1990 H reg if thats any gd to u.
PostPosted: Tue Mar 30, 2010 6:53 pm
PostPosted: Tue Mar 30, 2010 7:09 pm
is it still difficult to select first when its warmed up?
you dont have to listen to me tho :P, there is a mod for the linkage detailed on zetecinside.com scroll to the bottom of the link page :) (http://www.zetecinside.com/xr2/gearbox.shtml) as there is normally a bit of play in the u/j at the end, which will be magnified by the time it gets to the gearlever. also the guts of the gear lever can fall apart. again the bits for that are not especially expensive and i think it comes as a kit. fords themselves would be in a better position of advice that one. im pretty sure that would be the end of your sloppy gear lever. id try a gearbox oil change on that side of things to begin with. fords never put a drain plug on the BC boxes which means its very often neglected. only other thing i can suggest is (and you probs did it when you replaced the cable) is to reset the auto ratchet, lift up the pedal and let it reset then push the pedal all the way to the floor a couple of times. that might solve it.
Hope that goes some way to giving you an idea. i doubt it can be much else to be honest.
Jam.
PostPosted: Tue Mar 30, 2010 7:15 pm
PostPosted: Wed Mar 31, 2010 3:11 pm
Put it in second and give it a few more revs :thumbsup:
PostPosted: Wed Mar 31, 2010 7:09 pm
ok, how are you meant to change the g/b oil then with no drainage??
PostPosted: Wed Mar 31, 2010 8:00 pm
something your used to wayne...pull a shaft ;)
PostPosted: Wed Mar 31, 2010 8:05 pm
tart, lol
PostPosted: Wed Mar 31, 2010 8:09 pm
queen. your only jealous im not more local lol
PostPosted: Wed Mar 31, 2010 8:11 pm
i am, its fun though having you explain things to me via txt then have to re explain it in simple terms, lol pmsl
PostPosted: Wed Mar 31, 2010 8:16 pm
if our lives were as simple as you young man then the world would be a far easier place to live in. altho women would have to carry pepper spray!
lets stop spamming this thread shall we :D
PostPosted: Wed Mar 31, 2010 10:24 pm
no keep going its funny :lolz:
PostPosted: Wed Mar 31, 2010 10:34 pm
yeah but i feel a bit guilty spamming it large on someones technical help thread to take the micheal out of that old orange queen.
I have MSN for that :lol:
PostPosted: Wed Mar 31, 2010 11:19 pm
haha, its all good fun mate, nice to have someone on the same level of piss taking as me!!!!
PostPosted: Thu Apr 15, 2010 9:23 am
could be nakered pressure plate or gear linkage worn m8
Users browsing this forum: Google [Bot] and 82 guests
