Fiesta-Si.com • View topic - XR2i - problem
It is currently Thu Mar 26, 2026 2:07 am
 Post subject: XR2i - problem
PostPosted: Sat Mar 27, 2010 3:34 pm
Hi, im Bruno and i'm form Portugal.I have a Fiesta XR2i (1990), but im having some problems now.
After 2k rpm the car doesnt accelerate as it used to be, has a lot of difficult to rev.
We've checked the ignition coil , injectors. The other parts (ecu, ignition module and the sensor system) i cant try because i dont have spares.
Does anyone had a problem like this?
Thanks.
 Post subject: Re: XR2i - problem
PostPosted: Sun Mar 28, 2010 11:09 pm
try taking the exhast off....ive had it before where the guts collapse and end up blocking it....
PostPosted: Tue Apr 06, 2010 6:48 pm
Tried but no luck :|
Already tested some components in another car and they are all ok.
Now , i just want to burn my car :banghead:
PostPosted: Tue Apr 06, 2010 8:40 pm
sounds liek to much fuel check the fuel pressure and compressio0n test it m8 also chweck the voltage on thesensors throttle sensor is the one that wud cause that check the timing aswell
also crankshaft sensor can be an issue if its breaking down
Users browsing this forum: No registered users and 128 guests
