Fiesta-Si.com • View topic - Is there bolts missing from my sump?
PostPosted: Thu Mar 18, 2010 10:18 pm
my boyfriend was underneath the car today just doing some final checks and having a look at the oil leak i have.
Good news is he thinks the oil leak is the sump gasket. Bad news is, he thinks theres some bolts missing from my sump.
Theres two holes on the front of the sump that look like there are missing bolts. 99.9% sure there is supposed to be bolts there as there is a thread for them. Are we right in thinking that it is missing bolts?
PostPosted: Thu Mar 18, 2010 10:30 pm
a picture would help, but if there are two holes in the sump flange which show 2 matching threaded holes in block, sounds definatly like two are missing
PostPosted: Thu Mar 18, 2010 10:43 pm
well if theres holes in he sump for bolts and he ain there then yes they are
there aint any redundant holes on the sump
thats whats proberly causing your oil leak
PostPosted: Thu Mar 18, 2010 10:47 pm
will get a pick up tomorrow for you
The holes aren't helping so will get some bolts to sort that out. The boyfriend says that oil is leaking from the top of the sump so sump gasket is the first thing that comes to mind
PostPosted: Fri Mar 19, 2010 1:00 am
if its at the back of the engine the oil pressure switch is a favourite for going wanky..its just above the sump in the block has a single wire going to it on an angled terminal... just a thought ;)
Jam.
