Fiesta-Si.com • View topic - steering rack
It is currently Wed Mar 11, 2026 11:36 pm
 Post subject: steering rack
PostPosted: Thu Mar 11, 2010 6:16 pm
hey ppl..just wondering whether someone could tell me which rack and column i would need to run non power steering on my si???
and if anyone has got a setup for sale :thumbsup:
RuLeThEbEnDs
 Post subject: Re: steering rack
PostPosted: Thu Mar 11, 2010 9:00 pm
hi mate any mk3 non pas rack
if you can get one use a rs turbo rack as its a quick rack.
you will also need the steering coloum aswell as they are different from a pas one.
a blanking plate will need to be made to blank up the hole for the steering coloum as the pas one has a bigger hole than non pas and you will need the grommit.
i have a rs1800/xr2i steering rack for sale
PostPosted: Thu Mar 11, 2010 9:11 pm
also forgot to add you will need a non pas front engine mount with altinator bracket
PostPosted: Fri Mar 12, 2010 2:25 am
hey bud thanks :thumbsup: i bought a non pas rack and column off a mk3 at scrappies but they didnt seem to lign up right through the bulkhead not in the centre of the hole..not sure if this is because of the rack been off a mk3 and mine been a mk3.5???
how much would you want for the rack matey?? :)
RuLeThEbEnDs
PostPosted: Fri Mar 12, 2010 9:50 am
i had this problem its due to the different steering coloums
you need to blank up the hole and cut a smaller hole for the non pas coloum and rubber boot
can do the rack for £30 posted due to the weight
or you can collet from pe33
PostPosted: Fri Mar 12, 2010 11:34 am
