Fiesta-Si.com • View topic - superchips problem :(
 Post subject: superchips problem :(
PostPosted: Sun Mar 07, 2010 2:52 pm
I had a plug in superchp in my car and it worked fine for months..... But all of a sudden it started to idle funny bouncing between 500 and 1000 rpm then in started cutting out untill the point were it wouldn't start at all so just to see if it was the chip I unpluged it and hey presto car run perfect is this normal? and do you think it would just reset its self if I plug It back in ?
PostPosted: Mon Mar 08, 2010 12:57 am
myt av just come loose to were it plugs in mate, seems to happen alot on the fiestas my mate just put sum tape over his
PostPosted: Mon Mar 08, 2010 12:31 pm
Also try putting it in and resetting the ECU
In the process of murdering my second Si :'(
PostPosted: Mon Mar 08, 2010 12:44 pm
take the chip out and plug it straight back in, secure with tape, disconnect battery for half hour. plug back up and let it tick over for 10 mins to re learn everything!!
hopefully should solve it dude!!
PostPosted: Mon Mar 08, 2010 7:10 pm
Agree with the above but 5 mins with the battery disconnected should be enough!
PostPosted: Mon Mar 08, 2010 8:52 pm
well im now running a boost vavke will this make a differance to the chip or damage my boost valve ??
PostPosted: Mon Mar 08, 2010 10:20 pm
Nah won't alter the chip, might confuse the ECU slightly I suppose, just reset the ECU so it can get its readings again...
Should reset it whenever you change anything to do with the air inlet/fuelling etc
PostPosted: Tue Mar 09, 2010 2:54 pm
put the chip in and it doesnt really work well with the mods that iv already made so its now for sale if anyone is intrested ??
