Fiesta-Si.com • View topic - Handbreak night on dashboard
PostPosted: Sun Feb 28, 2010 6:54 pm
For the people who dont no i have a Y reg silver ka collection, 30.000 miles on the clock and has just passed its m.o.t!
When i break to a stop or slow down to turn a corner the handbreak night shows up on the dashboard, and no the handbreak isnt on :doh:
Ive checked the break fluid and that is fine, could it be the handbreak light senser? or something a bit more technical?
K.Louise
PostPosted: Sun Feb 28, 2010 7:30 pm
check that the handbrake cable is tight enough but not too tight, we have a peugoet partner at work with a similar problem but it had it tightened and it was fine.
PostPosted: Sun Feb 28, 2010 7:53 pm
if you put your hand on the hand brake lever and push it down does it stop it coming on? and does it come a long way up when on, if so as said above could need adjusting a bit so when off its not so slack, or check switch not loose
PostPosted: Mon Mar 01, 2010 1:07 am
When you pull you pull your handbrake up (whilst stationary, of course) does the foot brake appear to go slack??
