Fiesta-Si.com • View topic - Temperature gauge...
 Post subject: Temperature gauge...
PostPosted: Sun Feb 21, 2010 10:52 pm
Noticed my temperature gauge never seems to move off the black, then tonight when I took it out, it seemed to intermittently jump into the middle and back down into the black...is this likely to be the sender, or wiring?
I've had a problem in an old K plate Escort where it shot up to the red and stayed there, but not had this before...
In the process of murdering my second Si :'(
 Post subject: Re: Temperature gauge...
PostPosted: Mon Feb 22, 2010 1:33 pm
if it intermittently jumps sounds more like wiring than sensor, there is a way of testing in the haynes manual if i remember by shorting wiring out and gauge should go to top, might be worth a look if you got one.
PostPosted: Mon Feb 22, 2010 3:21 pm
Cheers, will have a go at that - think I might know what the problem is though, its ridiculously low on coolant, i.e. nothing in the header tank! Don't know how I didnt notice it tbh! Going to drain it and flush it all out and put fresh stuff in, as I reckon the levels probably not touching the sensors or something like that! The car;s had a front end knock at some point, possibly a fucked radiator
PostPosted: Sun Feb 28, 2010 2:59 pm
my temp gauge needle goes to half way mark but still blowing cold air any ideas ???
PostPosted: Sun Feb 28, 2010 7:32 pm
your heater is nakard.
my temp works when it feels like it lol
PostPosted: Sun Feb 28, 2010 7:34 pm
aint that signs of head gasket about to poo itself??
PostPosted: Sun Feb 28, 2010 7:49 pm
if was really low on water could be a air lock in heater matrix,
PostPosted: Sun Feb 28, 2010 9:36 pm
so a new heater matrix required ?
PostPosted: Sun Feb 28, 2010 9:57 pm
PostPosted: Sat Mar 06, 2010 2:19 pm
ok got all the air out of the system and topped the water up still waiting for the temp valve unit to arrive the heater gets very warm but the question i really want to ask is when the engine gets warm shold the fan kick in to cool the system down even without the temp control valveand there feels like ther is no pressure in header tank when i go to unscrew the cap any help would be appreciated in solving this cheers
PostPosted: Mon Mar 15, 2010 11:44 pm
i think it maybe time to change a few pipes on this engine and flush the system out completely and hopefully the fan and sensor will work how they should do when new coolant is added im hearing a slight noise from header tank ie like its got and air leak or does any 1 have any better solutions ?????
