Fiesta-Si.com • View topic - cutting out issues
It is currently Fri Dec 26, 2025 3:21 am
 Post subject: cutting out issues
PostPosted: Sun Jan 24, 2010 10:21 pm
hi there. iv recently got a 1.4 1994 si :) however i do have an issue with it. when pulling up to lights or junction it can cutout. been told that if i disconnect the air flow meter this issue will stop?
any help would be most welcome
Cheers John.
 Post subject: Re: cutting out issues
PostPosted: Sun Jan 24, 2010 10:33 pm
doesnt sound like a maf fault tbh does it rev clean?
Coming soon
PostPosted: Sun Jan 24, 2010 10:35 pm
not sure aint really taken it far coz it cuts out :(
PostPosted: Mon Jan 25, 2010 11:05 am
not really had dealing with the 1.4 Si but it sounds like its the ISCV too me
take it off and give it a clean with brake/carb cleaner
PostPosted: Mon Jan 25, 2010 11:11 am
PostPosted: Mon Jan 25, 2010 1:43 pm
Don't the CVH engines have problems with blocked breather hoses? might be worth a check. Sounds awfully like ISCV though if it's the same mechanism as Zetec ones...
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Wed Jan 27, 2010 3:32 pm
i had this in my 1.3 when i stared it and left i tit would cut out and i change the plugs and lead and fine now
PostPosted: Fri Jan 29, 2010 12:09 am
alright mate! noticed your from south wales? where abouts are you?
ive had to 1.4 sis now.
clean idle speed control valve up like onslack said and also clean up the round black box thing next to the top left of the rocker cover! its a breather valve thing or sumin but they get clogged up with gunk.
also give it a good service and it will run much better! :thumbsup:
