Fiesta-Si.com • View topic - Fan belt
 Post subject: Fan belt
PostPosted: Wed Dec 23, 2009 3:20 pm
Im a complete utter newbie when it comes to cars. Never even looked under a car bonnet until i was 18 so am clueless. The alternator belt slipped off the other night but didnt snap. I have had a go at putting it back on but it is too slack, how to i tighten the tensioner to tighten the belt back up.
I see where the tensioner is but simply do not know how to tighten it. Any help would be so helpful thanksyou!! :D
 Post subject: Re: Fan belt
PostPosted: Wed Dec 23, 2009 3:52 pm
i've not done this in ages o might be slightly off, but i think you need use an allen key too move the tensioner and then tighten the bolt with a spnner
i might be well off so have a check here too :lol:
viewtopic.php?f=4&t=2545
PostPosted: Thu Dec 24, 2009 7:23 pm
The tensioner moves as you loosen/tighten the bolt 15mm iirc. Use a spanner to get in there should be a quick fix. Its a multi V belt so i dont see how it would slip off. Sounds like you have it the wrong way around or a tensioner/idle pully has broken. If it is non pas (if they do an SI with out pas) then the ajustment is through the alternator as they dont use a tensioner or idle pulley hth
onslack thats the cambelt
PostPosted: Tue Dec 29, 2009 6:55 pm
is it an automatic tensioner or a manual tensioner?
Users browsing this forum: No registered users and 119 guests
