Fiesta-Si.com • View topic - Immobiliser HELP!!!
It is currently Thu Mar 26, 2026 12:45 am
 Post subject: Immobiliser HELP!!!
PostPosted: Sun Dec 13, 2009 2:06 am
My problem is that when I lock the car, either immediately or whenever it feels like it, the horn will beep in short bursts and the red immobiliser light will be constantly on.
Eventually it will sop and the light will go out enabling me to start the car, but I need to find out what is causing it as its driving me (and neighbours) mad.
It doesn't help that I have a 139db air horn fitted.
Any help much appreciated
 Post subject: Re: Immobiliser HELP!!!
PostPosted: Sun Dec 13, 2009 10:46 am
may be of help
PostPosted: Sun Dec 13, 2009 12:21 pm
Thanks, I read through all of the info on pats but none of the error codes fit with my problem. It is as if the car thinks someone is trying to break in.
Does anybody know where the sensors are (if any) that tell the car if someone is trying to break in.
Could it also be an earth fault?
Thanks
PostPosted: Sun Dec 13, 2009 2:39 pm
Is it a ford alarm or aftermarket?
PostPosted: Sun Dec 13, 2009 7:26 pm
It is a standard ford alarm and immobiliser.
PostPosted: Thu Dec 17, 2009 7:27 pm
Car was tooting away when unlocked today. I got in and for some strange reason I was able to start the car when the red immobiliser light was on under the clock?
Any ideas on what is causing this.
Thanks
PostPosted: Thu Dec 17, 2009 7:38 pm
sounds too me like your ford pats system is throwing its toy's out the pram :lolz:
you might need another, its a small unit that goes around the ignition barrel, check its not fallen off or something, i do have a spare somewhere drop me a pm if you want it :thumbsup:
