Fiesta-Si.com • View topic - no 2nd gear in 1.4 si help
It is currently Thu Mar 26, 2026 12:47 am
PostPosted: Fri Nov 20, 2009 10:53 pm
hi i need to replace my gearbox as i have lost second gear for some reason what gearbox will fit and last longer cheers i am not intrested in top end as dont want to lose license yet so would like faster pull away hope someone can help cheers
PostPosted: Fri Nov 20, 2009 11:55 pm
I have a gearbox if your interested mate £20 collected, came off my 1.4 so will bang straight on!! :thumbsup:
B65 postcode
PostPosted: Sat Nov 21, 2009 12:44 pm
hi i am affraid you are about 2 and a half hours away and i cant drive my car at the moment but does sound good
PostPosted: Sun Nov 22, 2009 12:46 am
will a 1.3 gearbox give better pull away than the 1.4 si gearbox
PostPosted: Mon Nov 23, 2009 1:48 am
PostPosted: Mon Nov 23, 2009 11:10 am
thats what i have been told but scared to put a 1.1 box on it as i would probaly blow that up :banghead: wanted the lsd turbo box on it but it will make it slower pull away (higher gear ratio i have been told) so do you no what other gear boxs will go on the 1.4 fsi that will keep the pull away as obviously i am not going to break speed records in a 1.4 :(
PostPosted: Mon Nov 23, 2009 12:01 pm
Despite popular belief the lower boxs are as strong as the higher boxs so a 1.1 box would be fine.
Surely your car is still drive able, I can go without 2nd.
PostPosted: Mon Nov 23, 2009 4:28 pm
hi dont no if it the gear box now as my clutch went lastnight so might just be new clutch and cable as it very stiff so now car dont move just revs and i can select gears while car is running so dont no what to do :x
