Fiesta-Si.com • View topic - Can you put a rear mounted starter motor zetec engine in a..
PostPosted: Sat Sep 19, 2009 3:39 pm
fiesta? lol couldnt fit that last word in the title.
Basically, as some of you might be aware, im converting my 1.3 into a 1.6 and while messing with the engine today unplugging it all and that ready to be taken out, i realised it has a rear mounted starter motor (engine is coming from an escort), basically all i need to know is will it be able to be put the engine into the fiesta? The starter is mounted up near the top of the gearbox too...
Im sure i will, i dont see why not. I just need someone to confirm its all ok or not lol
PostPosted: Sat Sep 19, 2009 6:27 pm
Found out now lol, answer is yes :D
Also found out you can put a fiesta gearbox on and make it front mounted starter instead of rear... so all is good :D
PostPosted: Sat Sep 19, 2009 8:05 pm
so czan you have the starter on the back of the engine with a standerd 1.6 si gear box as i want to make a custom exdorst and i want to move the starter motor?
PostPosted: Sun Sep 20, 2009 12:37 am
You cant with a standard 1.6 gearbox because the hole for the starter is at the front of the gearbox, if you was to get a gearbox which had the hole for the starter at the back - ie. and escort one, you could put the starter at the back.
PostPosted: Sun Oct 04, 2009 11:22 pm
does evry thing connect up the same with a escort box as with a fiesta box ? plus is there any way at all to usse a foesta box with the starter motor at the back ?
as i want to use a LSD .. or will a fiesta turbo LSD fit in the escort box?
PostPosted: Mon Oct 05, 2009 6:22 pm
PostPosted: Mon Oct 05, 2009 7:50 pm
ok soo can i just use the bell housing insted of changing the entier gear box?
PostPosted: Tue Oct 06, 2009 2:27 pm
Well if the bell housing is changed the gearbox has to come out. Takeing gearboxes apart is not easy, unless you know what your doing.
PostPosted: Wed Oct 07, 2009 12:29 pm
Replacing the bell housing is a simple nuts and bolts job is it not?
I was under the impression that the bellhousing was removed from the engine side of the gearbox rather working towards it from the other end!!
Paul :thumbsup:
PostPosted: Wed Oct 07, 2009 9:37 pm
Not quite a simple nut and bolt job :thumbsup:
PostPosted: Wed Oct 07, 2009 10:44 pm
oh well lol
PostPosted: Tue Oct 20, 2009 5:37 pm
ok i just want to ask one more quiestion i have now got a escor engine and gear box (1.8) with starter at the back ... i take it it will all fit ok
