Fiesta-Si.com • View topic - Gearbox oil: [Leaking Driveshaft !]
It is currently Thu Mar 26, 2026 7:57 am
PostPosted: Thu Sep 10, 2009 9:29 am
Only a quick question, ive got a leak from a seal somewhere on the gearbox. Never messed with oil in the gearbox before. Can anyone tell me where abouts i top it up or atleast a way of checking the oil level in there. Getting some whining in the box so just wanted to top it up until i can get the seals sorted.
 Post subject: Re: Gearbox oil ?
PostPosted: Thu Sep 10, 2009 9:33 am
iirc there is a nut on the passenger side of the gearbox near that breather pipe thingy, thats where jamie and i filled his up :thumbsup:
if i can get a pic before i head out i'll high light the area
PostPosted: Thu Sep 10, 2009 9:43 am
PostPosted: Thu Sep 10, 2009 9:49 am
here a pic
i think it was this nut, if not its around that area somethere :red: :lol:
umm.. we just topped it up untill it started coming out the hole :lol:
as for draining it, i'm not sure, check the online hanynes ;)
PostPosted: Thu Sep 10, 2009 9:55 am
no drain hole on a bc box
you have to take it off :doh:
or take the driveshaft out of one side and jack up the other :lol:
PostPosted: Thu Sep 10, 2009 10:05 am
Thanks, yer i've found the plug you highlighted in the pic. I dont want to drain it though just top it up. Any particular grade\brand of oil i should use or just that universal gearbox stuff. Its ERST LSD gearbox if that makes any difference ?
PostPosted: Thu Sep 10, 2009 10:07 am
80/90 oil is what we used on ford boxes before :thumbsup:
PostPosted: Thu Sep 10, 2009 10:08 am
PostPosted: Thu Sep 10, 2009 10:09 am
np :)
PostPosted: Thu Sep 10, 2009 1:17 pm
managed to get the plug off that Terry was on about, started pouring in the oil and it was pissing out the passenger driveshaft where it meets the gearbox as quick as i was pouring it in. This would explain why the gerabox isnt holding oil and my mystery oil leak. This mean new driveshaft or just a case of getting a new seal or something ? Looks like the driveshaft has come away from the box ? can anyone explain the pics ?
PostPosted: Thu Sep 10, 2009 2:34 pm
Managed to push the driveshaft back in fairly easy but wont it just as easy pop back out again when driving ?
PostPosted: Thu Sep 10, 2009 5:26 pm
shouldnt do matey if its on the circlips then it should stay in there did you pull it back to see if it was in place and you can tell if its griped again
PostPosted: Thu Sep 10, 2009 5:58 pm
PostPosted: Thu Sep 10, 2009 6:12 pm
yeah probly something like that as it only needs a shape solid tug to bring it out but i would think it would stay in as its only same as taking it out to do a clutch or something along them lines
PostPosted: Thu Sep 10, 2009 6:19 pm
PostPosted: Thu Sep 10, 2009 6:22 pm
yeah do one job and see another 5 jobs that need doing lol
PostPosted: Thu Sep 10, 2009 6:26 pm
PostPosted: Sun Sep 13, 2009 7:54 pm
PostPosted: Sun Sep 13, 2009 8:32 pm
ermmm not to sure think its possoblly the gearbox as there a slit in the drive shaft for them im sure someone here will tell you definattly
cant really see how its popping out at motorway speeds
your drive way sounds a bit like mine oil all over it by any chance
PostPosted: Sun Sep 13, 2009 9:10 pm
Its because your car is lowered i rekon. how much is the drop on it ?
Its probably made worse by something worn or wearing... ie a mount or bush etc
