Fiesta-Si.com • View topic - 2ltr question?
 Post subject: 2ltr question?
PostPosted: Sun Aug 23, 2009 11:14 pm
Hi there, iv just put a 2ltr engine in my Si. i put air filter on it so where the pipe from the cam cover went on the air box iv put a little filter. my problem is its throwin oil out the filter!
how can i stop this from happening?
also i am going to be looking into putting a desial gearbox on it. what clutch would i be able to run it is as i want to uprate the clutch aswell.
Cheers Grant
 Post subject: Re: 2ltr question?
PostPosted: Sun Aug 23, 2009 11:40 pm
Standard clutch is fine.
It's an oil breather pipe. Oil will come out of it.
PostPosted: Mon Aug 24, 2009 1:08 am
but i want to uprate it as it slips abit on take offs.
and ok thanks for that. do you think its worth makin a catch tank for it as i dont want it goin all over my gearbox
Grant
PostPosted: Mon Aug 24, 2009 8:34 am
im running a breather filter with no problems, which way is it pointing? could be you engine is breathing a lot, are all the breather pipes clear and the one into the inlet manifold?
As for clutch's i previously fitted 2 cheap ebay clutches and ripped the centre out of them within 500 miles, since then fitted a Helix uprated performance clutch, but at £300 was expensive, for road use though would think there would be ones about for £100.
if you look at link below can see my breather filter, its mounted vertically so any oil drains back into the cam cover.
PostPosted: Mon Aug 24, 2009 10:16 pm
PostPosted: Tue Aug 25, 2009 7:10 am
PostPosted: Tue Aug 25, 2009 3:58 pm
PostPosted: Tue Aug 25, 2009 7:33 pm
