Fiesta-Si.com • View topic - 2litre cylinder head interchangability
PostPosted: Mon Aug 10, 2009 7:03 pm
is it possible to replace a silvertop cylinder head with a later black top cylinder head which has solid lifters? and is the 1.8 head different to the 2litre?
PostPosted: Tue Aug 11, 2009 3:48 pm
Not sure on the blacktop head swap... but to be honest I cant see why not. I'm sure ive seen a blacktop st170 head on a silvertop bottom end.
1.8 vs 2.0 head.
A 1.8 head on a 2.0ltr bottom end will raise the compression ratio abit. So that would be ideal for you as your n/a with throttle bodies ;)
PostPosted: Fri Aug 21, 2009 8:07 am
It will fit. Just bare in mind, 1, what paul said, 2, tensioner pulley/belt arrangement is different.
