Fiesta-Si.com • View topic - Slight problem
It is currently Thu Mar 26, 2026 12:47 am
 Post subject: Slight problem
PostPosted: Thu Aug 06, 2009 6:19 pm
When I drive sometimes the car chokes.. I dont know what it is or whether "chokes" is the right word but basically..
for example i was sat at about 3000rpm in 4th and i slowed down to 2500rpm and the car bumoed, as if you were kangarooing it when you were learning to drive and couldnt control the clutch. the exhaust (being loud) kinda chokes and the car bumps a little, its noticable but not affecting too much. it happens at other times too, say i floor it in first as it kicks in itll bump once, twice maybe even three times and its annoying.. just wondered if anyone knew what it was? cheers
 Post subject: Re: Slight problem
PostPosted: Thu Aug 06, 2009 6:45 pm
plugs, leads or somethings restricting the fuel, maybe fuel filter or faulty pump ?
PostPosted: Thu Aug 06, 2009 6:59 pm
PostPosted: Fri Aug 07, 2009 8:34 pm
no that wouldnt be it. it sounds like a misfire to me. do what 95 fiesta si sed to do mate, just checked anything to do with the ignition system or fuel system.
PostPosted: Fri Aug 07, 2009 8:37 pm
actually. engine mount??
if u plant ur foot then shut off, can u feel the car like jerking?
PostPosted: Fri Aug 07, 2009 9:49 pm
PostPosted: Fri Dec 04, 2009 3:16 am
i kinda have the same problem dose it when i lift off and sometimes when i floor it, sometimes worse than others, dosent always happen though,
feels exactly like bad clutch control whilst pulling away.
I WANTS BOOST!
PostPosted: Fri Dec 04, 2009 3:44 am
dosent always happen when i floor it tho, i could just be driving around normaly and it will happen,
i cant decided if its a problem worth fixing or not tho :thumbsup:
I WANTS BOOST!
PostPosted: Fri Dec 04, 2009 10:33 am
Try changing plugs and leads and go from from there. Sounds like the same sort of thing my 106 was doing as well, might be overfuelling
Users browsing this forum: No registered users and 112 guests
