Fiesta-Si.com • View topic - need help!! induction kit viper
It is currently Thu Mar 26, 2026 7:31 am
PostPosted: Wed Jul 22, 2009 10:09 pm
hi guys need your help is this setup that i have done for the induction kit right or is it a total shambles lolImage
would appreciate your views thanks :thumbsup:
PostPosted: Wed Jul 22, 2009 10:22 pm
it is on fiesta mk4 1.3 ghia
its a viper induction kit
PostPosted: Wed Jul 22, 2009 11:27 pm
I thought the vipers where enclosed with a feed?
PostPosted: Wed Jul 22, 2009 11:32 pm
if its a sealed viper filter would think the flexi hose a bit long, would be better with the silicon hose angle from the throttle body - MAF - Viper can between engine and battery or bit further forward and then the cold air flexi hose feeding the filter with cold air from the valance area, only pic i can find at mo.
PostPosted: Wed Jul 22, 2009 11:41 pm
hmm its weird because it gives out very good performance compared to before, better throttle response and quicker accelaration and mid range speed and noise has improved as well
but have probably fitted it wrong
its an odd one lol
PostPosted: Thu Jul 23, 2009 12:39 am
What will posted is what I was expecting.
PostPosted: Thu Jul 23, 2009 7:59 am
Is there another pipe after the enclosed filter? you normally route it to a foglight and replace it with the Si's, create a hole or route it under the bonnet.
Though if you're intake after the viper is where you fog light is, your car is low and you live in a very dodgy area when it rains and there's lot of puddles and what not, try investing in a Air Bypass Valve as well.
PostPosted: Thu Jul 23, 2009 11:17 am
hi guys thanks for the help ive found out what the problem is
ive put the cold air feed pipe where the standard hose pipe should be and the cold air feed pipe needs to go at the other end of the viper kit
only thing is is that im not sure where i should lead the cold air feed pipe to?
PostPosted: Thu Jul 23, 2009 12:30 pm
that sounds better :thumbsup: did the original air box have a standard cold air feed pipe, on a Si think it goes towards a area beside the radiator behind the bumper height ish
PostPosted: Thu Jul 23, 2009 2:58 pm
erm no i dont think so
and yea i had a rough idea it would be fed to the grill area
PostPosted: Thu Jul 23, 2009 2:59 pm
i was wondering if i cleaned my standard hose pipe out will it make much difference in performance if it has been cleaned?
PostPosted: Thu Jul 23, 2009 3:02 pm
It won't do any harm to clean it, might aswell if you have got the chance.
