Fiesta-Si.com • View topic - who has fitted a 2l without PAS?
It is currently Thu Mar 26, 2026 3:42 am
PostPosted: Wed Jul 22, 2009 4:04 pm
i have but i cant figure out what drive belt i need!
im using the si alternator mount so if any 1 know which 1 i need please reply as im now nearing the end of my project :thumbsup:
PM if u want u advert here :D
PostPosted: Wed Jul 22, 2009 4:13 pm
Should be the 1.6 Si one.
If you think about it when you do a 2.0 conversion you are basically just replacing the 1.6 block with a 2.0 block, pretty much everything else around it remains '1.6' as such.
PostPosted: Wed Jul 22, 2009 4:15 pm
nope, the si has the power steering wheel on the drive belt, i dont, i only have the water pump. crank pulley and alternator.
ps i started with a 1.1hcs
PostPosted: Wed Jul 22, 2009 4:22 pm
I see the problem. It been a few years since i had my 2.0 so just trying to remember where everything went.
Not sure the best way, of course a shorter one would do, but which is a good question. Is it not an option to fit part of the PAS system just so the pulley is there?
PostPosted: Wed Jul 22, 2009 4:27 pm
PostPosted: Wed Jul 22, 2009 4:33 pm
Yeah you can see just fitting the pump would solve the problem, as you would imagine most people just do the conversion on a 1.6 so its a none issue.
Maybe somebody else will have a better plan.
PostPosted: Wed Jul 22, 2009 7:12 pm
hi there,
best place to look would be kit car sites as they use the 2 litre silver top without power steering all the time!
hope that gives you a shove in the right direction!
I would look it up but I'm on my phone just now!
paul
PostPosted: Thu Jul 23, 2009 11:27 am
XR2i 1800 Zetec NON PAS engine mount, and belt will be perfect.
I didnt have pas in the pickup so I routed the pas pumps pipes around to itself so it just ran fluid round itself constantly.. worked fine, although abit pikey.
PostPosted: Thu Jul 23, 2009 11:36 am
does that lok like this?
PostPosted: Thu Jul 23, 2009 11:48 am
PostPosted: Thu Jul 23, 2009 12:59 pm
PostPosted: Thu Jul 23, 2009 6:40 pm
PostPosted: Thu Jul 23, 2009 11:40 pm
Sorted :thumbsup:
PostPosted: Fri Jul 24, 2009 6:38 pm
the 1 i bought was 1000mm but was a fraction too small, the next 1 they do he said was a 130, im guessing he means a 1130, which is 130mm longer, i think that may be a tad too long :(
pick it up tomorrow.
PostPosted: Sat Jul 25, 2009 10:03 am
well i got my new 1, when he said 130 he meant 13mm, but i know for a fact that's still be too small so opted for a 1075, an extra 75 may sound like a lot but i recon (and hope) that any additional slack is taken up by the tensioner :thumbsup:
also looking to botch together some coolant pipes, get the fuel lines connected to the tank and try and start her for the 1st time :D
some how i think that for whatever reason she wont but im hell bent on having her running today.
PostPosted: Sat Jul 25, 2009 10:33 am
have you tried the xr2i 1.8 zetec drivebelt that have doesn't power steering
PostPosted: Sat Jul 25, 2009 3:38 pm
PostPosted: Sat Jul 25, 2009 7:46 pm
the 1.8 zetec is identical to the 1.6 zetec in the si so getting the belt for the xr2i without pas will fit a treat as that's what it's for.
paul
PostPosted: Sat Jul 25, 2009 7:50 pm
and ur positive of this?
its the bracket om not sure about.
if i buy 1 and it doesnt fit will u refund me the money? :halo:
PostPosted: Sun Jul 26, 2009 9:31 am
I tried an XR2i non pas belt.
Didnt fit with the zetec pas mounting.
Hence why Ive ran 6 months with the pas pump still in place routing fluid around itself to stop it ceizing up.
Users browsing this forum: No registered users and 107 guests
