Fiesta-Si.com • View topic - 2.0ltr refusing to run.. SORTED.
It is currently Thu Mar 26, 2026 7:31 am
Post new topic Reply to topic  [ 62 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Mon Jul 13, 2009 9:52 pm
Right its got one more week otherwise the Fiesta Pickup is going to the scrapyard.
2.0ltr engine is refusing to run properly.
Turn the key, revs to 3k and dies.
Faffed around and removed the maf after holding the throttle for abit and it idles slightly
Sounds like its running on 3 or maybe 2... pops and bangs and sounds like a sack, revs near enough alright tho.
So its basically un usable.
Spend 2 hours removing the inlet tonight and sealing it up as I thought it was down to an air leak, but of course in true zetec wank style it made no difference!!!!!
The idle valve is the working one which was used on my RS1800 engine, along with my TPS, so they are working.
F*ck knows whats up with it. Ive had near enough all the problems zetec can have but ive never had this before, as its just weird and doesnt run properly full stop.
PostPosted: Tue Jul 14, 2009 12:51 am
didn't you say you were running it on the RS1800 ECU....could this not be it?
PostPosted: Tue Jul 14, 2009 7:09 am
PostPosted: Tue Jul 14, 2009 7:15 am
don't scrap it :)
i'm sure you could sell it without a running engine easy enough :thumbsup:
i'm guessing you have checked the plugs leads and coilpack :)
PostPosted: Tue Jul 14, 2009 7:20 am
PostPosted: Tue Jul 14, 2009 7:22 am
good luck with it :)
apart from that, i can't see what the problem is :cry:
although my old escort si wouldn't rev past 4.5k i got the ecu reset and a new maf sensor and it worked :doh:
bloody zetecs :lol:
again for some reason!
posted again for some reason
PostPosted: Tue Jul 14, 2009 7:52 am
I hate zetecs. When they go wrong they do it good!
PostPosted: Tue Jul 14, 2009 8:02 am
bloody double post :rolleyes:
yeah i hope it gets fixed :thumbsup:
PostPosted: Tue Jul 14, 2009 8:32 am
http://uk.answers.yahoo.com/question/in ... 054AAfL1hO
maybe no use, but that was a mondy running on 2 cylinders :red:
PostPosted: Tue Jul 14, 2009 9:10 am
Will definately fit the RS1800 coilpack later as I know for a fact that was working lol.
The 2.0ltr one was fine but its been sat doing nothing for a few months now so its probably fooked.
Come to think of it when I unplugged a lead it didnt seem like it was sparking very much compared to what my rs did....
PostPosted: Tue Jul 14, 2009 10:15 am
hopefully that sorts it :thumbsup:
i was bored at work so googled zetec engine problems and that mondy one came up :lol:
PostPosted: Tue Jul 14, 2009 8:16 pm
coilpack plugs and leads make no difference.
they are sparking fine.
hold the revs on and unplug each lead and you can tell the difference so its throwing some sparks in as it should.
pops and bangs like hell and ive got to hold the revs on to stop it cutting out
it must be an air leak still surely for it to pop and bang like that!?
exhaust sensor cant affect it that much i dont think
fooooooook sake
PostPosted: Tue Jul 14, 2009 10:31 pm
did you change the crank sensor?, it the timing ok?, and have you looked in to the injectors bled the fuel through the little shrader valve and it might be your ecu not liking the engine ohhh and the litttle earth that goes around the back of the engine to the drivers side try that as i had the same thing
PostPosted: Tue Jul 14, 2009 10:51 pm
PostPosted: Wed Jul 15, 2009 3:12 am
RuLeThEbEnDs
PostPosted: Wed Jul 15, 2009 7:49 am
Ah never noticed one.
Might just slap a big ass earth onto the engine and hope it works
PostPosted: Wed Jul 15, 2009 8:37 pm
atleast ur is starting m8, ive got the 2l in and i cant even get it to turn over!
PM if u want u advert here :D
PostPosted: Wed Jul 15, 2009 11:49 pm
