Fiesta-Si.com • View topic - Going to run my car with out a air flow
It is currently Thu Mar 26, 2026 12:03 pm
PostPosted: Thu Jul 09, 2009 2:05 pm
what would it do?
PostPosted: Thu Jul 09, 2009 2:09 pm
PostPosted: Thu Jul 09, 2009 2:45 pm
But for some reason it runs betta lol?
Would it fuck the engine?
PostPosted: Thu Jul 09, 2009 2:49 pm
If you are running the 1.4 ECU it won't be setup for the Xr2i engine :thumbsup:
get hte xr2i ecu fitted properly
PostPosted: Thu Jul 09, 2009 2:50 pm
PostPosted: Thu Jul 09, 2009 2:55 pm
Ok thanks.
The only thing is i cent see the ecu in the engine bay :S
PostPosted: Thu Jul 09, 2009 2:57 pm
thats because its not in there :P :thumbsup:
its in the passenger footwell IIRC
but i don't think its as simple as unplug 1.4 si ECU and plug in Xr2i ECU due to pats!
PostPosted: Thu Jul 09, 2009 3:07 pm
seriously mate :)
you can't run the Xr2i engine of the 1.4 ECU as it won't be setup for the engine and will underfuel etc :(
research how eaxctly the Xr2i ECU works with the 1.4 Si PATS system :)
unless someone on here knows :thumbsup:
PostPosted: Thu Jul 09, 2009 3:16 pm
Ok i will have to research just one thing tho could i get it remapped instead?
PostPosted: Fri Jul 10, 2009 8:15 am
Not much of a technical whizz, but surely would be cheaper for you to find an ECU off a motor in a scrap yard than turn up at a place to re map one, even if it is possible??
Fezzie Si 1.6 1995
PostPosted: Fri Jul 10, 2009 11:11 am
Just get the proper ecu and wiring loom.
Cheaper.
Easier.
PostPosted: Fri Jul 10, 2009 2:19 pm
But would it all plug in?
i am crap with cars :(
PostPosted: Fri Jul 10, 2009 7:49 pm
when me and jason talked about this the other day, he sed it dont matter about the pats system. because its external it will plug in and go.
PostPosted: Sat Jul 11, 2009 12:13 am
If it doesnt work you dont have to mess with the PATs system.
XR2i full loom.
Stop faffing and just fit the proper stuff to save hassle. Trust me.
PostPosted: Sat Jul 11, 2009 11:49 pm
just to put everyone up todate i am running the 1.4 si ecu cuz the xr2i and the si 1.4 use the same fuel and it is well fast lol . took it out to night it sipins up in 2nd lol
PostPosted: Sun Jul 12, 2009 12:08 am
PostPosted: Sun Jul 12, 2009 11:35 am
Lol that is funny
well a see how it goes my uncle who fitrted it said the xr2i and the 1.4 si us the same fuel system 8-)
PostPosted: Sun Jul 12, 2009 5:43 pm
PostPosted: Sun Jul 12, 2009 5:50 pm
yea a 1.6 is gona use more fuel ini!!!
and i bet your running a 1.4 fuel pump which will be strained by the needs of a 1.6.
