Fiesta-Si.com • View topic - would no lambda give u bad idleing??
PostPosted: Fri Jul 03, 2009 11:07 pm
hi there will having no lambda on give you bad idlein?? as mine will jump from 1k-2k then back at stand still in traffic lights etc, also the engine seems to want to cut out coming off my drive, cheers
PostPosted: Sat Jul 04, 2009 12:04 pm
In short, yes
With it removed you've got a gaping hole in the exhuast which would upset the balance, and without the sensor reading it should go into a limp mode to compensate.
Sensors are there to improve the efficiency of an engine.
PostPosted: Mon Jul 06, 2009 3:01 am
i was replacing my clutch cable when i noticed my lambda was not plugged in for some strange reason. didnt notice any differance with it in or out :S
PostPosted: Wed Jul 08, 2009 11:23 am
physically removed or just unplugged?
you'll not really notice it if it's unplugged, it'll just run rich.
unless there's more problems it should run ok.
PostPosted: Wed Jul 08, 2009 11:28 am
PostPosted: Wed Jul 08, 2009 11:35 pm
put the originaly maf housing back on, it'll probably run fine then
