Fiesta-Si.com • View topic - Bending stainless rod(exhaust hanger)
It is currently Thu Mar 26, 2026 1:23 pm
PostPosted: Wed Jun 17, 2009 8:32 pm
Need to bend a bit of stainless rod which is an exhaust hanger on a backbox.....would it be possible to heat it with a blow torch then bend it over 90 degrees with a pair of mole grips?
If not any ideas how?
PostPosted: Wed Jun 17, 2009 11:39 pm
if you can heat it all the better, but if just normal stainless rod should be able to bend it once at 90degrees cold, put it in a vice and then slide onto it a decent piece of tube for increased leverage and bend it over. if its just a hanger can make it out normal mild steel which will still mig weld onto a stainless exhaust ok. (not mank stainless exhausts have stainless steel hanger)
PostPosted: Thu Jun 18, 2009 6:22 pm
I prosume its just normal stainless steel? Its just a custom backbox thing. Right i'll get it in a vice then and try find a bit of pipe to bend it over after heating it a bit.
cheers for the info
PostPosted: Thu Jun 18, 2009 7:50 pm
just like this
PostPosted: Sun Jun 21, 2009 2:26 pm
Looks simple enough....just need to find someone with a vice :)
