Fiesta-Si.com • View topic - Flatspot after fitting NEW cat and lambda?
PostPosted: Thu Jun 11, 2009 11:09 pm
Hi, i fitted a new cat and a new Ford lambda sensor and now i have a low rev flatspot would you put this down to lambda sensor? even though it is a ford one and it is new i didi get it off a guy on ebay who said it would work in my car and is the 4 wire type. anyone ever came across this with a new lambda or even new cat?? thanks
PostPosted: Thu Jun 11, 2009 11:14 pm
people say some times need to reset the ecu by disconnecting the battery for ten minutes or so to enable the ecu to re-learn, but someone must be able to confirm
PostPosted: Thu Jun 11, 2009 11:40 pm
PostPosted: Fri Jun 12, 2009 8:02 pm
I would put it down to the lambda then. If you know anyone in a garage, get them to do an emissions test on it, it will show if the lamba is working properly or not.
