Fiesta-Si.com • View topic - how to get the door pins out
It is currently Thu Mar 26, 2026 1:23 pm
PostPosted: Mon Jun 08, 2009 5:49 pm
got someone intersted in the doors how do i get the door pins out help appreciated
PostPosted: Mon Jun 08, 2009 6:01 pm
Open the door as far as it'll go. Then go and hi-jack a JCB and drive into it at maximum velocity.
PostPosted: Mon Jun 08, 2009 8:18 pm
as above, theyre a right PITA to remove, i couldnt get mine out, wd40, heat, u name it they were not having it.
PM if u want u advert here :D
PostPosted: Mon Jun 08, 2009 9:06 pm
douwse in wd40, get a nice fat drift and hammer take the little clip off then hit the drift on to the pin (short sharp shocks) the more times you hit the pin the more ikely you ul burr the edges over, so as great terrys chocolate orange ad says dont tap it wack it!
PostPosted: Mon Jun 08, 2009 9:09 pm
be gentle ;)
PostPosted: Tue Jun 09, 2009 10:16 am
last ones i had were fooked...ended up cutting the hinges off with a chisel.i think you can get a tool for them somewhere.....
PostPosted: Tue Jun 09, 2009 4:15 pm
Users browsing this forum: No registered users and 91 guests
