Fiesta-Si.com • View topic - Replacing The Speed Sensor (VSS)
PostPosted: Mon Jun 08, 2009 4:46 pm
anyone done the above and is it an easy job to do?
any sort of guide would be helpful or anyone knows a link/pics
i would probably be able to get round doing it meself but it is good to know from others of any issues that may arise when do the job
Cheers
John
PostPosted: Mon Jun 08, 2009 9:00 pm
unplug the wire that goes up the engine side of the engine bay undo the speedo cable think its a 22 or 21 mm nut douse the pin in the side of the vss in wd40 or stronger get some molegrips attach to the pin an hit the molegrips
now this is where it comes out or you start to swear at it as the pin some times snaps off :doh: (try not to snap it) :thumbsup:
once the pins out it should come out with a wiggle
PostPosted: Mon Jun 08, 2009 10:19 pm
PostPosted: Mon Jun 08, 2009 10:52 pm
underneath the car its ok to get at not sure about gong from the top its at the back of the gearbox you ull find the speedo cable going down to it
PostPosted: Mon Jun 08, 2009 11:57 pm
done mine from under the bonnet as i broke the pin cost me £50 at fords for a new one :doh: so i had a working speedo again
