Fiesta-Si.com • View topic - rev counter not working????
PostPosted: Thu Oct 06, 2005 8:28 pm
my rev counter does not work, sometimes when i bash the dash bord it starts to work :?
i assume it is a cable twisted or something. how do i take the dash off and fix this problem?
cheers
PostPosted: Thu Oct 06, 2005 8:49 pm
a screw either side of the wheel, pull the face off, pull the clocks out, pull the speedo cable and the wires out the back (easy) use a flat driver to seperate the clocks from the case (two clips) you now have access.
the car doesnt have a rev counter cable its electronic.
i fitted white dials and now mine sticks until i tap it gentle on the dash, i think the needle catchs on the slighly raised overlay.
there you go :)
then again all this maybe wrong! :rolleyes:
