Fiesta-Si.com • View topic - car wont start
 Post subject: car wont start
PostPosted: Mon May 04, 2009 10:27 pm
i have rescently had the head gasket skimmed and renewed and now the fiesta wont start
has any 1 got any ideas why???
we have tryed jump startin but that does work
 Post subject: Re: car wont start
PostPosted: Tue May 05, 2009 1:06 am
when u done the gasket etc
did u change the cam belt....
is the leads pluged to the correct plugs
does it turn over
maybe its seized try and turn the car over by hand...
if it dont move then maybe it is seized
keep us informed and all the clever heads on ere will help u out mate :thumbsup:
PostPosted: Tue May 05, 2009 1:10 am
this happened to me and a week or more playing around with things and nothing. but a thicker set of jump leads and it started stright away
PostPosted: Tue May 05, 2009 9:39 am
well wen i try and start the car it just sounds like its tryin to go but it doesnt fire up
PostPosted: Tue May 05, 2009 10:23 am
Sounds daft but are your leads in the right order? My missus' dopey uncle had this problem :lol:
You said in your first post you tried jump starting but it does work. Is that DOES work, or DOESN'T work?
PostPosted: Tue May 05, 2009 12:48 pm
doesnt work i mean
PostPosted: Tue May 05, 2009 12:59 pm
I refer to my first statement then, are your leads in the right firing order?
PostPosted: Tue May 05, 2009 1:08 pm
might sound silly but did you make sure it was timed up correctly?
PostPosted: Tue May 05, 2009 4:33 pm
well i got a fully qualified mechanic round to do the head gasket and everything else and now he hasnt came back to solve this and he wont answer his phone and im getting fedup as its been off the road 4 2 months now!!!!
PostPosted: Tue May 05, 2009 7:49 pm
Sounds like the usual mechanic if you ask me :lol:
Where are you based? Someone on here might be able to offer assisstance.
PostPosted: Tue May 05, 2009 9:58 pm
right tonight i checked the plugs and they were fine, it was fine wen i turned it over manually and the fuel pump is fine
what else can i check ???
PostPosted: Wed May 06, 2009 8:40 am
you getting a spark?
and definately getting fuel to the fuel rail?
PostPosted: Wed May 06, 2009 9:27 am
fuel is definately getting through
this might be silly but how can i check if im getting a spark?? I have had new spark plugs done
PostPosted: Wed May 06, 2009 9:33 am
good good that fuel is getting thro, did you check via the pressure relief valve on the fuel rail?
to check your getting a spark, remove a spark plug, re-attach your HT lead then hold the plug near some conductive metal and then get someone to turn it over :thumbsup:
look carefully at the plug to check you can see a spark
PostPosted: Thu May 07, 2009 2:26 am
PLEASE MAKE SURE u have all the leads on the right plugs and on the right terminal on the coil pack.......
by any silly chance has ur starter motor broken.......
try hit it with a hammer as it might have bin jammed... or the thing inside has snapped....
scrappy do these for 20pound for the whole motor and solenoid....
might not be but that could have happend......
PostPosted: Thu May 07, 2009 7:29 am
PostPosted: Fri May 08, 2009 2:53 pm
update:
yestaday i got my m8s brother round who is a fully qualified mechanic and use to own his own garage and he took a look at the car and found out that there is no compression in the cylinders
PostPosted: Fri May 08, 2009 3:51 pm
Job well done by the original mechanic then :lol:
Did your head gasket blow in spectacular fashion before then?
PostPosted: Fri May 08, 2009 6:47 pm
PostPosted: Fri May 08, 2009 7:04 pm
na sadly it didnt go spectatually
the mechanic that my dad got was shit and he didnt even put the timing belt on the right way or even tight so im lucky it hasnt caused any more damage
Users browsing this forum: No registered users and 102 guests
