Fiesta-Si.com • View topic - ENGINE STRUGLES TO TURN OVER.
It is currently Thu Mar 26, 2026 5:44 pm
PostPosted: Fri Apr 10, 2009 2:23 pm
this is my first post hope someone can help. my engine really strugles to turn over now and again as if the battery is dead. At first i thought it was the battery but thats fine. it will turn over eventually and start and runs fine. but the problem is worse when the engine is warm.
PostPosted: Fri Apr 10, 2009 4:26 pm
welcome to fsi, hopefully we can help with your issue :thumbsup:
could be completely wrong here, but too me it sounds like your starter is on its way out
i'm sure if i'm wrong someone will correct me :red: :lol:
PostPosted: Fri Apr 10, 2009 9:19 pm
Terry, you need to stop doubting yourself, you're a hell of a lot better with mechanical diagnosis than you used to be! We're all here to bounce idea's around, and yours are as good as any nowadays :D
Anyways, in regards to the problem, I had the same issue with my Si when I first got it. Would start up fine from cold, but once I'd driven for a while and got up to temperature, turn it off, then it would struggle its tits off trying to start!
Took the alternator off and got that checked, all fine. Wires were fine. Starter was fine. Turned out it was indeed the battery! If you can get a nice fresh one to borrow, try that first before you go dismantling things :) If that doesn't cure the problem, then I'd be looking at the alternator and starter motor :)
PostPosted: Fri Apr 10, 2009 9:58 pm
get a meter tester across the terminals of the battery, see what its kicking out!!
PostPosted: Sat Apr 11, 2009 10:18 pm
When was the last time it had new plugs and leads ?
PostPosted: Mon Apr 13, 2009 3:36 pm
PostPosted: Mon Apr 13, 2009 3:37 pm
PostPosted: Mon Apr 13, 2009 3:42 pm
PostPosted: Wed May 13, 2009 2:46 pm
take the plugs out and make sure the engine turns over with a decent battery
