Fiesta-Si.com • View topic - how to get 2 head gasket on 1.6 /water in sump problem
PostPosted: Tue Mar 31, 2009 9:48 pm
my bro has took the head off so we can see the cams and we took all the belts off as we just done the water pump but now we found water goin into the sump so we think its the head gasket ive looked in the haynes manuel but it doesnt say much about the head gasket so can any 1 shed any light on this???
PostPosted: Tue Mar 31, 2009 10:08 pm
iirc in order to get to the head gasket you'll need to remove the cam's and undo the head bolts, disconnect all the piping to the head/inlet/thermostat
simple as that i think :lol:
then remove the head :thumbsup:
sure someone will correct me if i'm wrong :red:
PostPosted: Wed Apr 01, 2009 7:34 am
You say your brother took the "head" off so you can see the cams? Well, he's only took the cam cover off then, the head is still attached.
PostPosted: Wed Apr 01, 2009 12:02 pm
i mean the cams cover not the head
PostPosted: Fri Apr 03, 2009 9:03 pm
buttery biscuit boost
Users browsing this forum: No registered users and 103 guests
