Fiesta-Si.com • View topic - heater blower
 Post subject: heater blower
PostPosted: Fri Mar 27, 2009 2:55 pm
hi all,
mine has stopped working after ticking for a round a week.... is there any soultion to fixing this, or is it anew fan jobby? if so where is the fan located??
thanks
 Post subject: Re: heater blower
PostPosted: Fri Mar 27, 2009 6:05 pm
You sure its the fan not a fuse or crap wiring, if not its def new fan jobbie :thumbsup:
If it is the fan they are easy to get to mate just need to remove parts to get to it.
Its behind the removable section of the bulk head! so if you look at your inlet the black panel behind that can be removed in two sections using philips screw driver on the few screws in the corners holding it on. Once you have removed this you will see the fan there in front of you. un-clip the two wires and undo the two 13mm bolts holding it in and it will slide straight out.
I tried finding a picture as that panel was removed on my si to show you what it looks like but this is the best i can find sorry its not clear.
If you look at my red power lead running up the back you will see a black box in the middle...that your fan mate :thumbsup:
Hope this helps
PostPosted: Fri Mar 27, 2009 7:28 pm
cheers thanks alot mate :thumbsup:
job done just had a look and it appered to be crappy wiring, cleaned up terminals and all good now!!!
thanks alot :thumbsup:
PostPosted: Sat Mar 28, 2009 3:14 pm
Slide right out? lol The worst bit I always find is removing the fan shield.Always seems to break! :doh:
PostPosted: Sat Mar 28, 2009 11:34 pm
yeah, im not going to lie to you.... i broke the fan covering hahaha :P
thanks
PostPosted: Sun Mar 29, 2009 12:00 am
When the car was new I bet that cover was easy as hell to remove as it had some flex in it,Now its brittle like pastry lol
Users browsing this forum: No registered users and 105 guests
