Fiesta-Si.com • View topic - oil leak
 Post subject: oil leak
PostPosted: Thu Mar 26, 2009 8:09 pm
hi
I bought my Si 1.6 in december for £500 and it did have a water leak but ive solved that with a new pipe. I was driving around the other dad and when i accelerated i heard a tingleling sound and so them it died. I found out that i had no water left and that a massive oil leak. The water problem was the water pump, so i have recently fixed that but i still cant find the oil leak!!! at the back of the engine i found a loose wire and i have looked in the haynes book and still cant tell what that wire is and where the oil leak is. The oil is underneath the engine on the left hand side. I fort it may have been the oil switch or valve but i cant find the valve:S and the switch. Also the 1.8 engine in the book looks exactly like my engine but mine is 1.6 and the diagram in the book of the 1.6 isnt mine. Is that a common problem????
cheers
Simon
PostPosted: Thu Mar 26, 2009 8:33 pm
soz rong info im a tit
 Post subject: Re: oil leak
PostPosted: Sat Mar 28, 2009 9:04 pm
nop because its at the back of the engine not near the front
PostPosted: Sun Mar 29, 2009 12:46 pm
Oil pipe? Zetecs have no oil pipes unless its turbo which requires oil reed and return. Do you mean the breather to inlet pipe?
Zetecs like eating crank oil seals. Also oil pump gaskets, there is a modified oil pump gasket which is metal rather than paper which is much better. Sump gasket? Rocker cover gasket leaking down onto stuff? Oil pressure switch?
Just a few options
PostPosted: Sun Mar 29, 2009 2:24 pm
What is this??? is that the oil pressure switch??? and do you no where it goes???Image
PostPosted: Sun Mar 29, 2009 9:18 pm
Pics not to clear to me but that looks like the steering rack?
PostPosted: Sun Mar 29, 2009 9:54 pm
ye i fink that is but do u no what that wire is?? that is circled in red???
PostPosted: Sun Mar 29, 2009 10:22 pm
Ah, the wire, that goes onto the oil pressure switch, just pushes on. Its on the back of the block.
PostPosted: Sun Mar 29, 2009 10:36 pm
is the block the sump???? and does it go under the oil filter????
PostPosted: Mon Mar 30, 2009 10:31 pm
The block is the block, and the sump erm well, the sump. Its above the oil filter and in the middle ish.
PostPosted: Tue Mar 31, 2009 9:04 pm
ok thanks :D
