Fiesta-Si.com • View topic - Can you name this pulley????
PostPosted: Thu Mar 26, 2009 6:55 pm
Hello all
driving along the other day at a fairly healthy speed, when suddently heard a noise and then the alternator light came on.... the power steering became....well non existant and i slowly started to over heat. yes basically my auxiliary belt went!!!!
but, when removing shards of the old belt i found one of the pulleys to be loose.... well completely detached form the engine block and nicely fused into the drivebelt cover to be exact :thumbsup: :lol:!
now have a new aux belt, but cannot seem to find this pulley anywhere. am i right in thinking its just a pulley, the tensioner one is above it is it not :hmm: :hmm:?? i cant find it anywhere in the haynes manual either. does anyone happen to have a spare one or kno where i can get hold of one??
1.6 phase2 16V Zetec if that helps anyone.
pictures below... more to follow...
PostPosted: Thu Mar 26, 2009 7:09 pm
ignore me :lol: , i did say it was the crank pulley, but i was looking in totally the wrong place :lol: :lol: :red:
that i think is the idler pulley that helps keep the belt under tension, with that coming loose, you'd loose drive the alt explaining the battery light and you'd loose drive to your water pump
which would explain the over heating, so imo i think you might have cooked the HG :cry:
ps. in photobucket use the code with the [img]code[/img] bits to add the pic into your post ;)
edit:- done it for you ;)
PostPosted: Thu Mar 26, 2009 9:58 pm
PostPosted: Thu Mar 26, 2009 11:04 pm
iirc the tensioner/ the one that you use when you change the belt is the top pulley
i'm assuming you can re-use your one?
i'll see if i can get mine off this weekend for you as i'm stripping my fez, will pm you if i manage it :D , but i wont be home till tuesday evening so wont be able to post it till wednesday/thursday :cry:
PostPosted: Thu Mar 26, 2009 11:06 pm
PostPosted: Fri Mar 27, 2009 9:30 am
drop me a pm with your mob number on it and i'll drop you a text tonight to let you know if i have manage to get it off :thumbsup:
