Fiesta-Si.com • View topic - possibly a timing problem on my 2 litre? need help!
It is currently Thu Mar 26, 2026 7:29 pm
PostPosted: Wed Mar 11, 2009 10:27 pm
well i put everything together turned it over for the first time and it wouldnt start just kept blowing the air inlet pipe off the maf (that isnt securely fastened due to the size of the 2 litre maf) i've got spark and fuel but its just not even trying
one thing i did notice is the inlet manifold was getting warm and the exhaust manifold was cold. I havent yet fitted the downpipe and unburnt fuel was dripping out of the exhaust manifold. upon inspection of the spark plugs there was also unburnt fuel on them too
i had the cambelt changed by a mechanic whilst the engine was out and i think he may have done it wrong. my theory is its opening the inlet valve when its sparking causing it to fire into into the inlet manifold and opening the outlet valves on a downstroke causing unburnt fuel to pass through to the exhaust
if im right how far out of time would it be to cause this and could it damage any valves?
i called the mechanic that did the cambelt to see if he would come out to check the timing again but he just fobbed me off :x
PostPosted: Thu Mar 12, 2009 11:53 am
sounds like a good mechanic!
it's fairly easy to check your timing.
take top cam belt cover and rocker cover off,
turn bottom pulley clockwise until first notch (IIRC) lines up with raised part of sump.
check slots at back of cams and try and fit cam locking tool in them
if it's timed up fine it should slot in
PostPosted: Thu Mar 12, 2009 12:27 pm
:shock:
sorry to hear this buddy, sounds like a top notch bloke :squint:
check here
viewtopic.php?f=4&t=2545
should tell you how to time it up :thumbsup:
its fairly easy to do, just turn it over by hand first(rachet on the crank pully) to make sure there is no valve and piston contact
PostPosted: Thu Mar 12, 2009 12:28 pm
bloomin cowboy :x
PostPosted: Fri Mar 13, 2009 2:45 pm
Hi there,
I would say that sounds like it's 180 degrees out!!
And if I'm right in what I'm thinking, that would make sense with opening the inlet on exhaust stroke and vice versa!
You'll be glad to know that shouldn't damage any valves as it's just opening the wrong ones on the wrong stroke.... I think!!
Follow that guide attached above and you should be sorted, would definatly try and get a 5mm flat bar to lock the cams when the crank is at TDC, will make life so much easier!!
Paul :thumbsup:
PostPosted: Mon Mar 23, 2009 1:39 pm
just to bump this topic up, i'm still no closer to finding out the problem the timing seems ok just wondered if anyone else has had this problem or may have an idea. need to get it back on the road sharpish!
cheers
PostPosted: Mon Mar 23, 2009 2:47 pm
sounds soo odd!
only thing i can suggest if you've double and triple checked the timing and its all A-ok then itm might be time to call a mobile mechanic or someone like that :cry:
PostPosted: Mon Mar 23, 2009 2:52 pm
definately odd :lol:
do as terry said :thumbsup:
PostPosted: Mon Mar 23, 2009 3:37 pm
Are you sure you've got the right piston at TDC when you are checking the timing?
Paul :thumbsup:
