Fiesta-Si.com • View topic - whats the normal engine oil pressure??
It is currently Fri Mar 27, 2026 1:12 am
PostPosted: Sun Mar 08, 2009 11:18 am
whats the normal engine oil pressure on my 1.6 si?
PostPosted: Sun Mar 08, 2009 2:55 pm
If its in the Haynes Manual it might be on here,
viewtopic.php?f=4&t=2545
Not 100% but thought I'd mention it anyway, another member gave me that link.
PostPosted: Sun Mar 08, 2009 4:20 pm
still carnt find where
PostPosted: Mon Mar 09, 2009 10:18 pm
Engine
Engine code L1E
Capacity 1597 (cc)
Idle speed 875 +/- 50 (rpm)
Valve clearance
Hydraulic
Compression pressure
Normal 12 - 14 (bar)
Oil pressure 2.0/2000 (bar / rpm)
Fuel system (make & type) Ford
Firing order 1-3-4-2
Timing stroboscopic (before TDC) 8 - 10/880 (° / rpm)
Ignition coil resistance, primary 0.45 - 0.55 (ohms)
Spark plugs (make & type) Motorcraft AYRF 22 PP
Spark plug gap 1.3 (mm)
Injection pressure / system pressure 3.0 (bar)
CO exhaust gas < 0.5 (%)
CO2 14.5 - 16.0 (%)
HC 100 (ppm)
O2 0.1 - 0.5 (%)
Lambda 0.98-1.02
Lambda change (Delta Lambda) 0.02
Oil temperature during test 80 (°C)
Fast-idle speed 2800-3100 (rpm)
CO at fast-idle speed < 0.3 (%)
Closed-loop test at: 700-1000 (rpm)
Cooling system
Cap pressure 1.2 (bar)
Thermostat opens at 85 - 89 (°C)
Fan on at 93 - 97 (°C)
Electrical
Battery 51 (Ah)
Alternator 55 (A)
Capacities
Engine sump, incl. filter 4.25 (l)
Cooling system 7.0 (l)
Users browsing this forum: No registered users and 89 guests
