Fiesta-Si.com • View topic - HELP!!!
It is currently Fri Mar 13, 2026 11:27 am
 Post subject: HELP!!!
PostPosted: Sun Mar 01, 2009 9:41 pm
I have a mk3 fiesta si 1.6 and its nakard so i was wonderin if anybody new whats up with it?
Basically it starts up fine but then cuts out straight away, if i hold my foot on the accelerator it keeps reving up but then the revs drop then revs up again then drops again etc, its as though its only gettin bursts of fuel through. Any help would be much appreciated
:thumbsup:
 Post subject: Re: HELP!!!
PostPosted: Sun Mar 01, 2009 9:59 pm
any one know where the isvc is located?
PostPosted: Sun Mar 01, 2009 10:15 pm
it's attached to the left hand side of the inlet manifold. dont get it mixed up with the TPS. someone may have a piccy?
ISCV sounds a likely cause. does it run rough as a bears backside? if so could be timing/fueling/valve related....
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Sun Mar 08, 2009 3:25 pm
a little but i put it down to not gettin a decent rough because it is un drivable. When i start it, it runs for about 2-3 seconds then dies off off unless i put foot on accelerator then it just rev's to about 1500 revs then drops then revs back to that magic number then drops again etc.
has anyone ever experienced problems like this?
PostPosted: Sun Mar 08, 2009 3:53 pm
PostPosted: Sun Mar 15, 2009 7:05 pm
cheers
