Fiesta-Si.com • View topic - CAMBELT replacment tips please!
PostPosted: Wed Feb 18, 2009 3:14 pm
my 1.6 si done almost 50000 im going to change belt plus auxilery belt, ANY TIPS AND ADVISE AND LIST OF TOOLS would be very much aprieated. oh and price of belts ta :) :)
PostPosted: Wed Feb 18, 2009 9:32 pm
i havnt done a cam belt while the engine is in the car but from what i have heard you have to drop the engine slightly to change to but im not 100% sure on that :? if not then i can see that it will be a pig to do and will need alot of patience as its a tight squeese getting your hand down the side of the engine :lol: make sure you change the tensioners ;)
PostPosted: Wed Feb 18, 2009 9:37 pm
Haynes manual is my best advise :)
Tools.. various sockets and spanners.
Lots of patience, and time.
Check, re-check, and check again, then check once more when done to make sure its all perfect as you dont want it to be a tooth out when it starts up! Or loose!
Not sure on price of the cambelt, but aux' belt is only a couple of quid. Might aswell do all the belts in that area while your at it, aux and alternator. New tensioner too. All in all, shouldnt be too much. Gen ford parts are best (cam belt and tensioner) aux/alt belt can be got elsewhere.
PostPosted: Thu Feb 19, 2009 9:52 am
cambelt is quite an easy job TBH. it's getting the bloody plastic covers off thats a pain in the arse!
here's a quick guide to doing it:
set engine to TDC using notch in bottom pulley lined up with raised mark on sump
remove aux belt using 14mm spanner on tensioner
remove top cambelt cover
remove rocker cover and fit cam locking tool into back of cams, you may need to turn engine over by hand slightly(use 19mm spanner on bottom pulley, turning clockwise)
support engine (ie bit of wood on top of jack on sump) this is to allow you to lower/raise the engine to get to different parts
loosen both front and back engine mounts, bear in mind there's a bolt that needs removing for the back engine mount that you need to access through drivers side front wheel just behiind the suspension strut
remove bottom pulley using 19mm socket whilst ensuring engine does not turn. you should notice that the woodruff key is at the top
remove water pump pulley using 8mm spanner on the 4 bolts
remove cambelt tensioner
remove cambelt make sure you look at the path the belt takes.
remove idler pulleys for cambelt
fit new idler pulleys
slide bottom pulley on to ensure bottom end still TDC then remove
fit new cambelt
fit new tensioner
tension belt to satisfactory tension
remove cam locking tool
turn engine over one turn clockwise by hand, ensure that engine returns to TDC at top and bottom by checking the marks on pulley line up and the cam locking tool fit's in the back of the cams. this is a must!
refit and secure bottom pulley
refit plastic covers apart from top one
refit water pump pulley
fit new aux belt
refit the engine to it's mounts
once again, turn engine over by hand ensure that it returns to TDC at top and bottom of engine
refit rocker cover ensuring cam locking tool is removed, good idea to use a new rocker cover gasket too.
job done.
i'd advise to buy a haynes manual as that will help you loads.
