Fiesta-Si.com • View topic - how do you adjust the clutch on a si can any 1 help
PostPosted: Sat Feb 14, 2009 11:26 pm
hi could any 1 tell me how to adjust the clutch on the si as my clutch works fine it selects the gears fine but the bite point is really far down and it is reallu uncomftale to live with :red:
PostPosted: Sun Feb 15, 2009 8:58 pm
ANY 1
PostPosted: Sun Feb 15, 2009 10:10 pm
on the clutch peddle arm there is a plastik nut if you turn that it will dissengage the ratchet set the peddle were you want it and tighen it back up to re-engage it
PostPosted: Sun Feb 15, 2009 10:24 pm
if you haven't got a manual adjusting pedal your clutch may be worn or cable excessively stretched
PostPosted: Sun Feb 15, 2009 10:55 pm
PostPosted: Tue Feb 17, 2009 9:34 am
you normally find most N reg ones have manually adjustable clutch's. basically, undo the white 'knob' on front of clutch pedal, wind it out until you feel it release, then wind it back in.
easy
PostPosted: Tue Feb 17, 2009 10:59 pm
cheers lads my whit nut had bin cracked and fell off found a plastic white nut on 1 of my lil bro's toys that worked perfect clutch is a lot better pulls off better and the bite point is better but i am still not happy with feel off the pedal so i am going to replace the cable any way see if it feels better cheers 4 the help lads :thumbsup:
PostPosted: Tue Feb 17, 2009 11:41 pm
the clutch cable is such a common fault it's unbelievable! some people go as far as carrying a spare!
PostPosted: Tue Feb 17, 2009 11:54 pm
Users browsing this forum: No registered users and 105 guests
