Fiesta-Si.com • View topic - problem with tyres
 Post subject: problem with tyres
PostPosted: Fri Feb 13, 2009 10:42 pm
was wondering if anyone can help me, i had my si lowered 60mm few months ago and went through a set of tyres in the matter of a weeks so i took it to a mechanic and he uprated my suspension arms and told me that would stop the inner edge of my tyres going bt now a few months later i have noticed that they are starting to go again, any ideas will be appreciated.
 Post subject: Re: problem with tyres
PostPosted: Sat Feb 14, 2009 12:43 am
Camber adjustable wishbones, get them from Ian Howell about £295 for a pair.
'Sideways Always'
PostPosted: Sat Feb 14, 2009 6:33 pm
try putting an extra 2/3psi in your tyres. i've been TOLD this helps, doesn't mean it will...
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Mon Feb 16, 2009 7:13 pm
PostPosted: Tue Feb 17, 2009 10:23 am
PostPosted: Tue Feb 17, 2009 7:54 pm
How do i make them myself and where can i get them bushes from?
PostPosted: Wed Feb 18, 2009 6:28 pm
ive got the same problem mines lowered 30mm and are bold on both inside edges only had the tyres on the car 3 months. not good can garages adjust the camber while doing tracking??
PostPosted: Wed Feb 18, 2009 8:36 pm
At 30mm you shouldnt be killing tyres that easily.. has the tracking been set up properly since lowering the car??
To make camber adjustable wishbones you need to make the ball joint go inwards. Not rocket science to figure it out.
Garages with the right equipment can do it, the ones with the laser alignment are the best
PostPosted: Sun Feb 22, 2009 7:06 pm
cheers 4 all ur advice will get to it in the morning and hopefully get it sorted.
PostPosted: Sun Feb 22, 2009 9:54 pm
my adjustable ones were £150
PostPosted: Mon Feb 23, 2009 12:33 am
PostPosted: Mon Feb 23, 2009 6:36 pm
PostPosted: Mon Feb 23, 2009 8:05 pm
Users browsing this forum: No registered users and 103 guests
