Fiesta-Si.com • View topic - zetec won't start
 Post subject: zetec won't start
PostPosted: Wed Feb 11, 2009 3:47 pm
It's a rs1800 It been sat since the summer ive charged the battery over night and showing 14v no dash nights looked at fuses all ok and clean. Could it be the ford immob can i take it out?
 Post subject: Re: zetec won't start
PostPosted: Wed Feb 11, 2009 4:04 pm
not entirely sure what it could be, was going to say a bad earth but i dont think its that :lol: :red: , it could be the PATS which i presume your car has
but again i'm not sure if that would cause the dash lights not to come on,i always thought the PATS system only cut spark and the fuel pump
hopefully someone with technical that me will be able to help :red: :lol:
PostPosted: Wed Feb 11, 2009 5:02 pm
Yes it has the pats as it hanging out the dash lol i think you right it may only cut the spark
PostPosted: Wed Feb 11, 2009 11:17 pm
pats only does the sparkplugs as i had a new key and all the car exepet the engine work as normal
PostPosted: Thu Feb 12, 2009 2:12 pm
Ive changed all the relays and no joy what's the white placstic electric thing around the lock?
PostPosted: Thu Feb 12, 2009 6:24 pm
Dumb question but when you put battery back on you did put all the connection on the earth side and on the positive side :S
PostPosted: Thu Feb 12, 2009 6:25 pm
PostPosted: Thu Feb 12, 2009 10:05 pm
Round the lock
PostPosted: Thu Feb 12, 2009 11:42 pm
i think thats what activates the central locking? i could be rong
PostPosted: Fri Feb 13, 2009 11:27 am
I was thing it was security it lock was broken i would start :?
PostPosted: Fri Feb 13, 2009 12:29 pm
gotta be a wiring fault somewhere.
you say the Pats is 'Hanging out of the dash' now it's a month since i've been in a fiesta but IIRC mine wasn't 'hanging out of the dash' :look:
have you connected the earth wire from chassis to battery? have you definately connected all positive cables?
if it was Pats stopping it from going the red LED in clock would display.
PostPosted: Fri Feb 13, 2009 4:09 pm
PostPosted: Fri Feb 13, 2009 5:01 pm
PostPosted: Fri Feb 13, 2009 5:04 pm
what exactly is happening when you turn the key then? does it turn over but just not fire into life?
PostPosted: Sat Feb 14, 2009 1:34 pm
The car only came with only one key and it wasn't the red key so i got the pats box out to change the lock's and pats one from a scrapped car with the red if that make sence but it allways started, then i left it as i was trying to find the hole set left it over the winter and now won't start or any light's on the dash the only thing that work and the c/locking and the clock but no red LED on the clock and the battery is just under 12v
PostPosted: Sat Feb 14, 2009 6:44 pm
no red LED tends to mean no PATS. either that or it's had the clock changed, but IIRC it's a different plug between PATS/no PATS clocks.
isn't there a main relay in the fuse box, a big green one springs to mind. i'm more certain to it being an Earth fault.
PostPosted: Sat Feb 14, 2009 9:26 pm
Ive got a bag of relays so i swaped them
Users browsing this forum: No registered users and 101 guests
