Fiesta-Si.com • View topic - steering??
 Post subject: steering??
PostPosted: Fri Feb 06, 2009 1:12 pm
i dont fink this is just the tracking out but im not sure...wen accelerating it pulls quite alot to the right and if i let off the pedal it pulls me for the kurb.its never done this before until i put the spax shocks on dont know if ive knocked anything.
any help but be great thanks :thumbsup:
RuLeThEbEnDs
 Post subject: Re: steering??
PostPosted: Fri Feb 06, 2009 1:45 pm
if you have had it apart, sounds like something wrong, have you lowered it drasticly as this will change stearing geometry, also have you checked nothing loose, miss placed as to pull to different sides could be something loose which is moving under the different forces
PostPosted: Fri Feb 06, 2009 2:40 pm
lowering the car will alter the amount of negative camber your car has and make it tramline more. i.e follow the camber of the road..into ruts etc...however your faults are more inline with knackered wishbone bushes. it will pull all over the place and generally drive like a turd.
wishbones are cheap enough. that would be where id start first..altho make sure you did things up tight before you go condeming bits.
hope that helps.
PostPosted: Fri Feb 06, 2009 3:53 pm
as Jam has said.. that sounds like nackered wishbones to me!!
what I'd do is replace the wishbones, track the car up properly.. if camber is bad mod the wishbones to alter the camber. sorted :chill:
PostPosted: Fri Feb 06, 2009 4:20 pm
ive had it lowered abit now and its only40mm,i just changed the shockers for spax ones.
ive just been and bought 2 bottom arms i knew i was ready for them so il let u know how it goes and yes it handles like a turd :lolz:
thanks :thumbsup:
RuLeThEbEnDs
PostPosted: Fri Feb 06, 2009 7:01 pm
is there anything else i could check by the eye while im under the car such as steering linkages etc :thumbsup:
RuLeThEbEnDs
PostPosted: Fri Feb 06, 2009 7:05 pm
get a big screwdriver and lever around the lower arms, lower ball joint and wiggle the wheel to look for any movement indicating problems
PostPosted: Sat Feb 07, 2009 12:20 am
check anti rollbar bushes.. what were the top mount ones like when you swapped the shocks ovedr?
PostPosted: Sat Feb 07, 2009 3:33 am
puttin the new arms on tomoro so il check around and the top mounts were all good :thumbsup:
thanks for the help people :)
RuLeThEbEnDs
PostPosted: Sat Feb 07, 2009 7:20 pm
well got my arms on today and it seems it probly will be those as my old ones were absolutely knackered :doh: goin out soon to test her :thumbsup:
ohh went to scrappys today for sum brakes and an 2.0 ecu...which code ecu do i need as the only ones i found was noah and sumfing else lol....also saw an escort rst in there with spax adjustables,goodridge hoses and grooved discs,will the disc and brakes fit onto my si from the erst??? thanks :D
RuLeThEbEnDs
PostPosted: Sat Feb 07, 2009 7:24 pm
2.0 ecu's that are nown to work are "DEEP" "DESK" and "DEWY" :thumbsup:
PostPosted: Sat Feb 07, 2009 8:44 pm
ok thanks, has anyone tryed the other ecu.s as there still the silver top engines n thought they mite work?? :thumbsup:
RuLeThEbEnDs
PostPosted: Sat Feb 07, 2009 11:47 pm
PostPosted: Sun Feb 08, 2009 3:14 am
ohh ok not great with all this wiring stuff lol just wanted sumone to explain why these were the only 3 to work but u cleared that :thumbsup:
and thanks thats gud im gunna go bk tomoro with some more tools and get the callipers n discs cause there like new :)
well thanks alot for your help 8-)
one more question :doh: how hard is a clutch ratchet to fit??? mines on its way out and gunna buy new one tomoro :D
RuLeThEbEnDs
PostPosted: Sun Feb 08, 2009 3:17 am
what reg am i lukin at for the mondy ecu as i always forget wot years they are :doh:
thanks
RuLeThEbEnDs
PostPosted: Sun Feb 08, 2009 5:39 pm
