Fiesta-Si.com • View topic - das vectra wont start help
PostPosted: Fri Jan 23, 2009 3:33 pm
my dads vectra has a problem the negine management light is on and the car wont revs above 4000 i cleaned the idle valve because it would keep stalling and cutting out but still hasnt solved the problem anyone help
PostPosted: Mon Jan 26, 2009 8:09 am
nice german sounding title :hsugh:
sounds like a cam sensor mate, as i had a vectra with the same prob :thumbsup:
PostPosted: Mon Jan 26, 2009 8:45 am
Just to point out, cleaning the ISCV doesn't mean you've ruled it out, it could still be buggered. :)
Is there no fault code test you can do on it, because the management obviously knows there's a fault as it won't let you rev past 4k? As Meilack said though, could be cam sensor.
PostPosted: Mon Jan 26, 2009 8:47 am
yeah it could be ISCV, but i know its a common fault on vectras for the Cam Sensor to go :rolleyes: and know exactly what he means as i was given one for free, but it had this problem :lol: she got scrapped :lol:
PostPosted: Mon Jan 26, 2009 9:41 pm
had it tested for codes showed nothing told to try crankshaft sensor by auto electrician and did the trick :thumbsup:
PostPosted: Tue Jan 27, 2009 8:04 am
i'm more then a pretty face it seems :lolz:
i got you in the right direction :lol:
PostPosted: Tue Jan 27, 2009 8:24 am
Err, so was it camshaft, or crankshaft? :)
PostPosted: Tue Jan 27, 2009 8:30 am
Crank/Cam sensor same thing :hsugh: :halo: :lol:
well on vauxhalls they both limit the car :rolleyes: and commonly go :rolleyes:
PostPosted: Tue Jan 27, 2009 8:37 am
But in actual fact, are completely seperate things! :lol:
And you've edited your post :lol: Tut tut.
PostPosted: Tue Jan 27, 2009 8:42 am
true
oh well i'm not a mechanic and its a vauxhall :lol: :red:
and me edit? mistake surely :hsugh:
either way its sorted :lol:
PostPosted: Wed Jan 28, 2009 11:09 am
a garage wanted like 100 quid just to fit it so i hada go myslef bit of a pain but got there :thumbsup:
PostPosted: Thu Jan 29, 2009 5:20 pm
I've replace a crank sensor on a vectra before, as you say, bit of a pain (does yours have aircon?) but can be done :)
