Fiesta-Si.com • View topic - deep ecu
It is currently Fri Mar 13, 2026 7:06 am
 Post subject: deep ecu
PostPosted: Mon Jan 19, 2009 12:33 am
hey guys my car alledgedly has a deep ecu what is this a chip or something any help much appreciated
 Post subject: Re: deep ecu
PostPosted: Mon Jan 19, 2009 12:40 am
No its a standard 2.0 ECU, but 2.0 eninges in fiesta's need specific ones: DEEP,
DESK, DEWY otherwise they don't run right. Just means it's got the right ECU in
it basically :)
PostPosted: Mon Jan 19, 2009 12:41 am
PostPosted: Mon Jan 19, 2009 10:21 am
thanks for clearing that up :thumbsup: did think it was a bit slow if it had been chipped whats the best chip to get
PostPosted: Mon Jan 19, 2009 10:25 am
superchips or powerchips i think they're called are the ones i have heard of, as for which is the best on i have no idea :lolz: :red:
PostPosted: Mon Jan 19, 2009 4:30 pm
mcaines :)
PostPosted: Wed Jan 21, 2009 9:09 pm
This has probably been asked before, sorry if it has, but since we are on the subject is there a sort of best one out of DESK, DEEP or DEWY to use or are they all the same ??? i seem to get the feeling people prefer to use DEEP over the others, is this just me ??? :thumbsup:
PostPosted: Thu Jan 22, 2009 9:41 am
they are all pretty much the same, but i have heard whispers that DEEP is the better one to use
not sure why that is though :hmm:
PostPosted: Thu Jan 22, 2009 11:11 am
I think its because most people have used the DEEP one and it worked so thats the one they recommend.
When I was looking for one everybody said DEEP works but they couldn't confirm the others did, so I went with that option, then due to that I can only confirm DEEP works so I do the same.
Chicken & the egg, everybody uses it, so everybody recommends it, so everybody uses it.
PostPosted: Fri Jan 23, 2009 2:08 am
DEWY worked fine on mine and will121 has had it RR'd at 140ish bhp from memory.
Emlyn
PostPosted: Sat Jan 24, 2009 12:38 am
they are infact all the same with the same map on them,
the codes listed above are all pre PATS
