Fiesta-Si.com • View topic - I need information on 1.8 conversion!
It is currently Thu Mar 26, 2026 5:45 pm
PostPosted: Wed Jan 14, 2009 10:19 pm
Right, ive thought about it and now im doing it. I have just bought all the bits i need to convert my 1.3 into a 1.8 zetec.
I have got the engine, loom, ecu, si fuel tank and pump, si struts and brakes ect
I dont need the ignition module(idrs or whatever it is) as my loom is from 1600 zetec and it has it built in ( i think anyway but this is not a problem as i have the ignition module too)
Has anyone got any pictures and information on the engine mount side of things and also wiring diagrams? And all the other info relating to this conversion.
Any help will be greatly appreciated
Thanks
Matt
1991 Polo GT Coupe
PostPosted: Thu Jan 15, 2009 8:16 pm
What year is your fiesta?
PostPosted: Sun Jan 18, 2009 7:40 pm
Its a M reg
I have everything i think i need to do the conversion
SI fuel tank, pump, struts, hubs, brakes, engine mount, ecu, loom, engine, ect ect ect
1991 Polo GT Coupe
PostPosted: Tue Feb 03, 2009 9:31 pm
If you have either the Si or rs 1800/16v xr2i engine mount then the engine is a straight drop in job. Also if you are using a 1.6 Si loom then it is just a case of fitting it then plug and play!! I converted a 1.6 Si a few years back to run on a 130bhp escort engine. Entire conversion took just under 4 hours start to finish, with cups of coffee in between!! :thumbsup:
blu-fez
blu is the new black
