Fiesta-Si.com • View topic - FIXED..was chip
 Post subject: FIXED..was chip
PostPosted: Mon Jan 05, 2009 4:49 pm
Right basically it only does this sometimes.. Then if you leave it overnight sometimes its fixed and wotn happen again for ages….. Basically.. When you turn first turn on ignigtion you hear the fuel pump prime then the relay click and it stops. On mine it then primes again constantly with the relay clicking trying to stop it but it just wont?!?!? Its not the relay before people say im not that dense… has it on a hand held fault code reader and it came back to wiring or fuel pump area… but said unknown code and you had to fix the problem you cudent just clear code…..
Right….. Do I need a new fuel pump?!?!?!
If so where is it and all that.. Got a 2.0 si.. Are they in the fuel tank.. I dunno if its standard or not?!?!
Etc etc etc HELP
PostPosted: Tue Jan 06, 2009 12:09 pm
sounds like you need a new fuel tank or something clotting it up mate, try running the tank bone dry then have a fiddle and see if anything jamming it if it seems ok then put some engine performance in and refuel if problems consist try new petrol tank all i can say.
PostPosted: Tue Jan 06, 2009 4:54 pm
not sure about on the Si's but i know on rst's if the pump is constantly priming it normally means the fuel system isnt holding pressure (the system needs to be constantly pressurised). can you smell raw fuel? if you can you may have a leak, or even possibly you might have a clogged fuel filter and the pump is working over time trying to allow enough fuel to pass though it?
PostPosted: Fri Jan 09, 2009 2:01 pm
im with the above. try a new fuel filter and look for leaks. failing that you might have a wanky pump thats not building pressure or pumping correctly causing the priming fault and thats a tank off job
how much effort does it take to start..does it still run..i.e alot of turning over before it fires into life
PostPosted: Fri Jan 09, 2009 5:20 pm
fire up straight away but cuts out if you dont hold revs as over fuels..then relay is just clicking loadsss and keepp pumping up the fuel just making the car spit flames
PostPosted: Sat Jan 10, 2009 12:36 pm
Id say, change fuel filter, check fuel pressure in rail. :thumbsup:
PostPosted: Wed Jan 21, 2009 9:41 am
update is.... as i had loads of suggestions... STILL BROKE..
still doing it on and off...
change maf, fuel filter. layed with wire to the pump.....still no luck :(
when taking ht efuel filter off fuel was highly pressurised.. it shouldnt be so should it..?
same as when going to refuel.... it goes..pssshhttt... like alot..... it should not be that pressurised should it?!
help me :(
PostPosted: Wed Jan 21, 2009 12:24 pm
ok i fixed it!!!!!!!!! well had help of what to do but ye
it was the chip
http://www.moates.net/product_info.php? ... cts_id=101
what everthat is ^^^^^^^ that was in it...
took it out rund great but no redline now? wierd but hey ho
 Post subject: Re: FIXED..was chip
PostPosted: Wed Jan 21, 2009 12:32 pm
glad you got it fixed buddy and it was nice and simple :thumbsup:
mine could never pull to the red line, yet jamiecliffe1988's and becks' would do, odd things! :rolleyes: :lol:
PostPosted: Wed Jan 21, 2009 12:48 pm
would with chip but overfuelled so meh.. hey means less restrictive ha.. i know were it used to redline so i wont hack it asmuch past there
PostPosted: Wed Jan 21, 2009 9:36 pm
glad you have it fixed now mate but i think the lack or red line you now have is all down to which ECU you are running, As the "red line" or "rev limiter" is programed into this by ford, as onslack says some peoples do and sum dont so i think this is to do with the different ECU's you can use. could be rong but try a different ECU and see what happens :thumbsup:
Users browsing this forum: No registered users and 101 guests
